[Qgis-developer] Change symbol \\ using jpeg image \\ and
proj(delimited text)
Gavin Macaulay
gavin at macaulay.co.nz
Thu Oct 5 04:44:07 EDT 2006
Schalk
I think you might have misinterpreted Martin's comment. Qgis knows about
projections for raster layers, but it is currently unable to reproject
raster layers. Hence if you have images in a known single projection, you
can display then, and also display vectors layers on top of them,
reprojected as necessary.
Regards
Gavin
> Hi Martin,
> Thanks again for reply!
>> Yes it's possible, it depends on whether you have jpeg support
>> compiled in GDAL library. QGIS currently doesn't support projections
>> for raster layers.
> I don't see any use for jpeg as a map if you cannot set the
> projection :-( Guess I'll have to use the shapefiles (perhaps simplified
> to save on loading time)
>> I haven't tried the code I've written here so maybe they won't work...
>> it's just how I think they should work :-)
> Worked perfectly last time! :-)
> Best Regards.
> Schalk
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
