[Qgis-developer] compile qgis svn
Martin Dobias
wonder.sk at gmail.com
Thu Oct 19 05:47:15 EDT 2006
On 10/19/06, Otto Dassau <otto.dassau at gmx.de> wrote:
> On Thu, 19 Oct 2006 09:45:22 +0200
> "Martin Dobias" <wonder.sk at gmail.com> wrote:
> > > Hi Martin,
> > > I guess I have to bother again, because I am still not able to compile a
> current
> > > QGIS SVN Rev 5967 from today (same error) but I was just able to compile and
> > > test the released Preview2 sources on the same debian sarge machine.
> > > Do you have another idea, what might be the problem?
> > Ok, let's give it another try :-) although I don't really understand
> > why preview compiles and SVN doesn't.
> Hi Martin,
> and I am a little confused, too :-), because when I tried to isolate the
> problem, yesterday after succesfully compiling the preview2 I also compiled svn
> revision 5879. I tried this special rev because I need the 2.5D support - and it
> also worked without any problems... hhmmm
> so I thought there must have been a change between rev5879 and rev5967...
> but this morning I tested the current rev5975 and it also compiled well. This is
> strange, because I didn't change anything just used make distclean and svn up
> a couple of times :-).
> maybe it was the r5967 by tim "sort out yy flax..." and I missed to clean the
> sources, yesterday?
> anyway - I'm happy now,
Glad that's finally working for you :-)
btw. Tim's changes in 5967 are related only to building with qmake and
don't affect building with autotools...
Martin
