[Qgis-developer] Building a macport/darwinport for QGis
Gary Sherman
sherman at mrcc.com
Sat Oct 21 12:15:25 EDT 2006
This message came in via the forum. I'm forwarding it to the list to
see if anyone wants to comment. Its probably best if you reply on the
forum: http://forum.qgis.org/viewtopic.php?t=136
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Hello,
I've recently entered the area of GIS and I've been building most of
my tools through the MacPorts/DarwinPorts system.
I thought I'd contribute a qgis portfile for version 0.7.4 but I'm
running into a build problem on qgisapp.cpp where I get an "error:
expected unqualified-id before string constant" error.
I'm building on an intel mac, and I suspect this error may be related
to a documented issue in the cmath header (specifically a problem
with the isnan macro).
I'm curious if anyone else has seen this issue and if so, what they
have done to fix it or workaround.
I'll also look into the libraries provided by macports. For example,
the qt-aqua bindings are at version 3 for macports, while I see most
people are using v4 for qgis.
Thanks in advance,
-Mark
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Micro Resources: http://mrcc.com
*Geospatial Hosting
*Web Site Hosting
"We work virtually everywhere"
