[Qgis-developer] Qgis Library Tutorial
Francis Bolduc
fbolduc at gmail.com
Tue Sep 5 09:27:37 EDT 2006
Good post on your blog! I think it will really help people who are
looking into qgis for the first time.
Also, I have a comment. If one wants to use qgis libraries after
having installed qgis, I would rather suggest beginning the
application with:
QgsApplication app(argc, argv, TRUE);
Rather than:
QApplication app(argc, argv);
Because QgsApplication, once instanciated, gives you access to the
plugin path. So instead of doing this:
QString myPluginsDir = "/home/timlinux/apps/lib/qgis";
QgsProviderRegistry::instance(myPluginsDir);
You can actually do it more simply like this:
QgsProviderRegistry::instance(QgsApplication::pluginPath());
Anyway, good job!
On 9/5/06, Tim Sutton <tim at linfiniti.com> wrote:
> Hi
> http://blog.qgis.org/?q=node/10
> Thanks again Francis!
> Regards
> Tim
> On 04/09/2006, at 19:51, Francis Bolduc wrote:
> As requested by timlinux, here is a simple project demonstrating how
> to use the Qgis library to create custom application. It consists of a
> single Widget containing a MapCanvas containing a PostGIS layer.
> Please feel free to copy/distribute/modify it as you want.
> The .pro file should be modified to suit your configuration.
> <main.cpp>
> <tutorial.pro>_______________________________________________
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> Tim Sutton
> Visit http://qgis.org for a great Open Source GIS
> Home Page: http://linfiniti.com
> Skype: timlinux
> MSN: tim_bdworld at msn.com
> Yahoo: tim_bdworld at yahoo.com
> Jabber: timlinux
> Irc: timlinux on #qgis at freenode.net
