[Qgis-developer] Qgis Library Tutorial
Tim Sutton
tim at linfiniti.com
Tue Sep 5 14:58:12 EDT 2006
Hi
Ah well spotted! That will probably make the 'cant find srs.db
messages go away too...
Thanks
Tim
On 9/5/06, Francis Bolduc <fbolduc at gmail.com> wrote:
> Good post on your blog! I think it will really help people who are
> looking into qgis for the first time.
> Also, I have a comment. If one wants to use qgis libraries after
> having installed qgis, I would rather suggest beginning the
> application with:
> QgsApplication app(argc, argv, TRUE);
> Rather than:
> QApplication app(argc, argv);
> Because QgsApplication, once instanciated, gives you access to the
> plugin path. So instead of doing this:
> QString myPluginsDir = "/home/timlinux/apps/lib/qgis";
> QgsProviderRegistry::instance(myPluginsDir);
> You can actually do it more simply like this:
> QgsProviderRegistry::instance(QgsApplication::pluginPath());
> Anyway, good job!
> On 9/5/06, Tim Sutton <tim at linfiniti.com> wrote:
> > Hi
> > http://blog.qgis.org/?q=node/10
> > Thanks again Francis!
> > Regards
> > Tim
> > On 04/09/2006, at 19:51, Francis Bolduc wrote:
> > As requested by timlinux, here is a simple project demonstrating how
> > to use the Qgis library to create custom application. It consists of a
> > single Widget containing a MapCanvas containing a PostGIS layer.
> > Please feel free to copy/distribute/modify it as you want.
> > The .pro file should be modified to suit your configuration.
> > <main.cpp>
> > <tutorial.pro>_______________________________________________
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> > Tim Sutton
> > Visit http://qgis.org for a great Open Source GIS
> > Home Page: http://linfiniti.com
> > Skype: timlinux
> > MSN: tim_bdworld at msn.com
> > Yahoo: tim_bdworld at yahoo.com
> > Jabber: timlinux
> > Irc: timlinux on #qgis at freenode.net
Tim Sutton
Skype: timlinux
Jabber: timlinux
