[Qgis-developer] CMake for building QGIS?
Tim Sutton
tim at linfiniti.com
Thu Sep 7 17:31:33 EDT 2006
Hi
Personally I dont see why we cant have multiple make systems in svn
assuming they dont conflict with each other....
If people feel strongly about having CMake (or in my case Id prefer
qmake) whats the harm? We should have a standard make system that we
use for official build instructions etc and in my mind thats where
the real debate lies. Even then we could provide multiple
instructions. If one make system begins to stand out from the others
perhaps it will become default just from user uptake.....
Regards
Tim
On 07/09/2006, at 15:20, Mateusz Loskot wrote:
> Martin Dobias wrote:
>>>> Some time ago I've read about CMake build system and that KDE
>>>> developers have switched from autotools to it for KDE4. I've
>>>> tried it
>>>> a bit and it looks very promising. This is a good reading for those
>>>> who don't know anything about it:
>>>> [1] http://lwn.net/Articles/188693/
>>>> [2] http://www.linuxjournal.com/article/6700
>>>> On page [1] you can find pros and cons of this system and
>>>> advantages
>>>> that developers of Scribus project see in it. It should suit our
>>>> needs
>>>> well as it has good support for different platforms and also it's
>>>> really easy to use in comparison with autotools. I've already
>>>> managed
>>>> to compile with it QGIS core library on linux.
>>>> What are your opinions about such switch for the next version of
>>>> QGIS?
>>>> I could try to prepare the build system in the refactoring
>>>> branch to
>>>> see if it works well.
>>> I started to like cmake, it's easier to write makefiles
>>> and Visual C++/KDevelop workspaces generation sounds promising.
>>> However, I still does not have any idea how to achieve something
>>> like dynamic configuration similar to ./configure scripts.
>>> IMHO, cmake is still under development and I'm not sure if it's
>>> very mature.
>>> I'd also like to hear more cmake pros and cons.
>> The best pros are that CMake's files are much easy to read and write
>> than those autoconf macros, configuration takes much less time,
>> generated makefiles are smaller, has graphical configuration (resp.
>> curses for unixes), Qt4 is supported out of the box. Also the choice
>> to use it for next KDE means that it's quite mature and will be well
>> supported in future.
> Indeed, simplicity is one of cmake's advantage.
> I'd add one more, that in comparison to autotools builds,
> cmake makes it extremely simple to keep all build configuration,
> build files out of the source tree.
> For example
> project/src - includes poor .h and .cpp files
> project/build - includes CMakeLists.txt + all generated stuff
> like Makefiles etc.
> I like clean source trees and cmake help to keep them as such :-)
> Another advantage is that creating new macros, m4 and autoconf
> equivalents, is very simple.
>> I see cons just in the need of learning a new language and that so
>> far
>> not many people are used to it.
> Right.
>>> BTW, recently one of GEOS user posted cmake for GEOS.
>>> I tunned it a bit and, as I said, I started to like cmake ;-)
>>> http://geos.refractions.net/pipermail/geos-devel/2006-September/
>>> thread.html
>> From the contributed cmake it's possible to see how simple can a
>> build
>> system be. Quantum GIS in addition needs just some 3rd party
>> detection
>> for Qt4, GDAL, GEOS, Proj4 and GSL, but I don't think it will be hard
>> to create them.
> It should be, see "How to write a FindFoo.cmake module"
> section on following wiki:
> http://www.cmake.org/Wiki/CMake_HowToFindInstalledSoftware
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20060907/7643610c/attachment.html
