[Qgis-developer] plugin question
humarco
marco.hugentobler at karto.baug.ethz.ch
Sat Sep 9 04:37:48 EDT 2006
Am Samstag, 9. September 2006 13:19 schrieb Radim Blazek:
> On 9/8/06, humarco <marco.hugentobler at karto.baug.ethz.ch> wrote:
> > Hi Radim,
> > > Yes, GRASS plugin stores current GISDBASE, LOCATION
> > > and MAPSET and it is reopened with project.
> > I saved a project with a GRASS layer, but I cannot find these elements in
> > the project file. Do I need to use the GRASS plugin in a different way
> > that these elements are saved? The project file is attached below.
> You must open a mapset first.
Ok, it works now. Thanks.
> > > BTW, I am writing a new plugin and I have 2 problems:
> > > 1) How to change it to standalone plugin with its own configure and
> > > make system.
> > I don't see the problem here. You need to check for the qgis libraries
> > (libqgis_gui, libqgis_core, ....), the qgis headers, the libraries qgis
> > depends on and for the location of the plugins. Otherwise a normal
> > autotool system.
> But how do you get all the dependencies of QGIS libs,
> for example postgres, geos, proj?
Isn't it possible to get them the same way as autotools do for QGIS? Not very
convenient for plugin writers though.
Marco
