[Qgis-developer] Debian packaging gridmaker missing
qgis at rigacci.org qgis at rigacci.org
Fri Sep 15 04:40:20 EDT 2006
On Fri, Sep 15, 2006 at 08:50:01AM +1200, Gavin Macaulay wrote:
> I had this problem too when making the rpms. It is caused by the lines:
> if MINGW_FALSE
> bin_PROGRAMS = gridmaker
> endif
> in the Makefile.am for the gridmaker and spit plugins. The if statement
> is evaluating to false in all cases, not just with mingw. The end result
The same problem for me building Debian Testing packages.
I just removed the install statement from debian/qgis.install, so
I have only the plugin version of gridmaker (which is working),
not the standalone program.
May be I will compile again...
Niccolo Rigacci
Firenze - Italy
Iraq, missione di pace: 41931 morti - www.iraqbodycount.net
