[Qgis-developer] QGIS Preview Release 2
William Kyngesburye
woklist at kyngchaos.com
Fri Sep 15 15:50:04 EDT 2006
On Sep 15, 2006, at 2:09 PM, Tim Sutton wrote:
>> What about the location of the Qt plugins?
> You can add search paths for qt plugns at runtime so they could be
> placed into the bundle.
Does the Mac QGIS do this now for the Qt plugins? If the Qt plugins
are included in the app package, they should be automatically
included in the Qt plugin search path, so the user doesn't have to
mess around with that.
>> I didn't notice, but is there an external QGIS plugins folder, like
>> in /Library/Application Support? This (and a user's home/Library) is
>> where any 3rd party qgis plugins should go - bad form to alter an
>> installed application.
> Ah good point. Bear in mind I am a mac neophyte :-) It should not be
> hard to add some mac specific code telling it to search in the
> /Library/Application Support/QGIS/ dir or whathave you.
That should be done at some time before a final release. And
probably use a subfolder in the QGIS folder, to keep things organized
- the App Supp could also potentially be used for user addons, like
themes, SVG graphics, etc.
Theere would be at least 2 folders to add to the QGIS plugins and
other extras:
$HOME/Library/Application Support/QGIS
Another not-so-common one is a network Library folder (can't recall
the exact path). The user Library should be searched before the
global Library, or, the user overrides the global.
Subfolders in both could be (mirroring what's in the QGIS app):
images/north_arrows
plugins
qt_plugins (for possible added Qt plugins needed by a 3rd party qgis
plugin)
svg
themes
And these would have to be added to appropriate search paths
automatically on startup.
I added a similar thing to my GDAL framework - replaced and added
extra search paths for GDAL plugins, instead of the default
$GDAL_PREFIX/lib/gdalplugins. Now it looks in the framework and the
local and user Library App Support.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly
what the universe is for and why it is here, it will instantly
disappear and be replaced by something even more bizarrely
inexplicable. There is another theory which states that this has
already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
