[Qgis-developer] Re: remove(dir) fails on Windows
Radim Blazek
radim.blazek at gmail.com
Fri Sep 22 14:45:17 EDT 2006
> > Hi.
> > remove() directory fails on Windows so that vectors cannot be deleted
> > without error. Patch for lib/vector/Vlib/map.c is attached.
> > IMPORTANT!
> Much worse is that a vector open in QGIS cannot be deleted.
> Open file on Windows cannot be deleted nor moved.
> That is very bad because it is very common to run a module
> again and again and watch results on display.
> I don't have any idea what could be done.
Output vector is now frozen when a module is started in GRASS tools
and thawn if finished with success. It is not perfect, does not
work from shell.
Radim
> Radim
