[Qgis-developer] Re: [GRASS-dev] QGIS Grass digit/v.digit and the
category 0 and 1
Radim Blazek
radim.blazek at gmail.com
Fri Sep 22 15:24:22 EDT 2006
The bugs are in QGIS and v.digit, you can fill bug reports.
Radim
On 9/22/06, Maciej Sieczka <werchowyna at epf.pl> wrote:
> Hi,
> Crossposting as the issue is both QGIS and Grass related.
> If I digitize a Grass vector in QGIS and add a feature using the 'next
> not used' category mode, the first category used is '1'. But, if I
> digitize a feature in 'no category' mode, add after that add a 'new'
> category in the Grass 'attributes window', the category added is...
> '0'. Why do this two situations differ? I suppose in both cases
> category '0' should be picked as the first one? Or '1'? One thing is
> sure cases the same should be used, but it's not.
> Moreover if, I do the same in v.digit (digitize a feature in 'no
> category' mode -> 'Display attributes' od that feature -> press 'Add
> new') v.digit issues an error: "Layer and category must be greater than
> zero" and I can't add a category to such a feature.
> The behaviour is incosistent (either 0 or 1 should be always used as
> the first category), leads to an error in v.digit, and it becomes
> problematic in QGIS Grass digit when I eg. digitize 100 features, then
> digitize one without category (eg. by mistake) and want to add a 'new'
> category to it. To my surpsrise the category added is not '101' but
> '0'. I would prefer categories were added in order.
> Would it be possible to fix that? Shall I fill a bug report? As I don't
> know if it's caused by some underlying Grass feauture or similar design
> of both digitizing tools - is it a bug in Grass, QGIS or both?
> Best,
> Maciek
> Panorama Internetu - prognoza pogody, poczta e-mail z największym załącznikiem, SMS, wyszukiwarki: Gooru, Anonser, serwisy: randki, ogłoszenia, wakacje, program TV, Kina, muzyka, DVD, newsy, inne.
> http://www.panoramainternetu.pl/ (http://www.epf.pl/)
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
