[Qgis-developer] GRASS edit: white vectors on white background?
Gary Sherman
sherman at mrcc.com
Wed Aug 1 09:48:53 EDT 2007
On Jul 31, 2007, at 11:11 PM, Otto Dassau wrote:
> On Wed, 01 Aug 2007 01:00:33 +0200
> Maciej Sieczka <tutey at o2.pl> wrote:
>> Otto Dassau wrote:
>>> Hi,
>>> When I display a GRASS vector map in current 0.9.0preview1 and
>>> switch to
>>> editing
>>> modus the line and vertices aren't visible anymore, except for
>>> some parts of
>>> the
>>> display with a background map. Looks as if white GRASS vectors
>>> are displayed
>>> on
>>> a white background.
>>> Does anybody else has experiences with this problem and can I
>>> change the
>>> color
>>> somehow?
>> I don't have such problem. Probably you have changed the line
>> color in
>> GRASS Edit. Go to symbology tab and check what line color is set.
> I didn't change anything and the lines should be displayed black.
> It happens
> only on my debian debian installations (I tried stable and testing).
> With opensuse 10.2 and it works fine as expected.
Any chance you are accessing your Debian boxes by remote X11 session
or VNC?
> The GRASS & QGIS installation is the same (qgis0.9.0pre1, GRASS 6.2.2)
> does someone using debian have the same problem with any GRASS
> vector files?
> thanks
> Otto
>> Maciek
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Chair, QGIS Project Steering Committee
Micro Resources: http://mrcc.com
*Geospatial Hosting
*Web Site Hosting
"We work virtually everywhere"
