[Qgis-developer] GRASS edit: white vectors on white background?
Otto Dassau otto.dassau at gmx.de
Wed Aug 1 10:14:55 EDT 2007
On Wed, 1 Aug 2007 05:48:53 -0800
Gary Sherman <sherman at mrcc.com> wrote:
> On Jul 31, 2007, at 11:11 PM, Otto Dassau wrote:
> > On Wed, 01 Aug 2007 01:00:33 +0200
> > Maciej Sieczka <tutey at o2.pl> wrote:
> >> Otto Dassau wrote:
> >>> Hi,
> >>> When I display a GRASS vector map in current 0.9.0preview1 and
> >>> switch to
> >>> editing
> >>> modus the line and vertices aren't visible anymore, except for
> >>> some parts of
> >>> the
> >>> display with a background map. Looks as if white GRASS vectors
> >>> are displayed
> >>> on
> >>> a white background.
> >>> Does anybody else has experiences with this problem and can I
> >>> change the
> >>> color
> >>> somehow?
> >> I don't have such problem. Probably you have changed the line
> >> color in
> >> GRASS Edit. Go to symbology tab and check what line color is set.
> > I didn't change anything and the lines should be displayed black.
> > It happens
> > only on my debian debian installations (I tried stable and testing).
> > With opensuse 10.2 and it works fine as expected.
> Any chance you are accessing your Debian boxes by remote X11 session
> or VNC?
yes, and it seems to be a hardware problem as Paolo described. Can this be
solved somehow, except with another video card?
regards,
 Otto
> > The GRASS & QGIS installation is the same (qgis0.9.0pre1, GRASS 6.2.2)
> > does someone using debian have the same problem with any GRASS
> > vector files?
> >  thanks
> >   Otto
> >> Maciek
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
> Gary Sherman
> Chair, QGIS Project Steering Committee
> Micro Resources: http://mrcc.com
>    *Geospatial Hosting
>    *Web Site Hosting
> "We work virtually everywhere"
