[Qgis-developer] change in QGIS-GRASS interface?
Leonardo Lami
lami at faunalia.it
Wed Aug 1 10:44:56 EDT 2007
Maybe it is linked to another bug:
see:
http://svn.qgis.org/trac/ticket/738
Leonardo Lami ha scritto:
> Hi all,
> I developed a series of QGIS-GRASS modules that are tested on QGIS vers
> 0.8 and vers 0.8.1 with good results.
> In the new vers (0.9) I see that there are some problems, when the same
> modules must show the fields of table linked to the chosen vector. For
> example the module that use the GRASS command v.to.rast with the option
> to convert a vector to raster using attribute values is:
> <?xml version="1.0" encoding="UTF-8"?>
> <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
> <qgisgrassmodule label=" v.to.rast - Convert a vector to raster using
> attribute values" module="v.to.rast">
> <option key="input" layeroption="layer"/>
> <field key="column" layer="input" type="integer,double"
> label="Attribute field" />
> <option key="output"/>
> <option key="use" answer="attr" hidden="yes" />
> </qgisgrassmodule>
> The string:
> show in the module window a string where you can choose the field to use
> as cell raster value between all the integer or double field of the
> linked table.
> Now in the vers 0.9 the same module, and the similar ones, don't
> work because the string where you could choose the field is now empty.
> There is same changes in the relation with GRASS?
> Or something to explain it?
> Thanks.
> Leonardo
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
