[Qgis-developer] QGIS 0.9.0 Preview 1
Martin Dobias
wonder.sk at gmail.com
Sun Aug 5 10:49:14 EDT 2007
python bindings really need sip 4.5 and pyqt 4.1 or later version.
That's because QGraphicsView started to be supported from pyqt 4.1 and
it has sip 4.5 as a dependency...
Martin
On 7/27/07, Otto Dassau <otto.dassau at gmx.de> wrote:
> Hi,
> to enable python bindings for debian I have following problems:
> -- SIP is required in version 4.5 or later!
> -- PyQt4 is needed in version 4.1 or later!
> debian stable and testing includes PyQt4 4.0.1-5 and SIP 4.4.5-4. Wouldn't that
> be sufficient?
> regards,
> Otto
> On Fri, 27 Jul 2007 13:50:53 -0300
> "Tim Sutton" <tim at linfiniti.com> wrote:
> > Hi All
> > Today I've tagged 0.9.0 Preview 1 as per our release plan at
> > http://wiki.qgis.org/qgiswiki/ReleaseChecklist0.9
> > You can check out a copy doing:
> > svn co https://svn.qgis.org/repos/qgis/tags/Preview-0.9.0-1 qgis0.9.0Preview1
> > This should bring into effect the following things:
> > - string freeze for UI - if you are a developer please dont change
> > any more UI elements or translatable strings
> > - call for translators to update ts files
> > - call for document managers to update docs based on new features in SVN
> > - call for packagers to create preview binaries
> > A source bundle for preview 1 will be made available soon.
> > Now is the time we call on your help to produce translations, update
> > documentation etc. You dont need to be a programmer to be of
> > assistance - all you need to do is be willing to donate some time and
> > have a computer.
> > Note that automake and qmake build systems are completely removed and
> > using cmake is the only way to build QGIS 0.9.0 preview 1. Please see
> > the INSTALL document in the source tree for detailed notes for your
> > platform. http://wiki.qgis.org/qgiswiki/BuildingFromSource Also
> > contains updated build notes for all platforms.
> > Many thanks for all who are pitching in to make this release happen.
> > Best regards
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
