[Qgis-developer] QGIS 0.9.0 Preview 1
Otto Dassau
otto.dassau at gmx.de
Mon Aug 6 02:35:03 EDT 2007
Hi Martin,
On Sun, 5 Aug 2007 16:49:14 +0200
"Martin Dobias" <wonder.sk at gmail.com> wrote:
> Hi,
> python bindings really need sip 4.5 and pyqt 4.1 or later version.
> That's because QGraphicsView started to be supported from pyqt 4.1 and
> it has sip 4.5 as a dependency...
thanks a lot for this info, so at the moment one has to compile sip and
pyqt from sources to get python binding support for debian etch and currently
also for debian testing.
There exists a NOTE for this in INSTALL.t2t and I hope there will be
package updates soon to make it easier to provide python binding support for
debian and other linux distributions. I think current opensuse 10.2 has the same
problem.
thanks
Otto
> Martin
> On 7/27/07, Otto Dassau <otto.dassau at gmx.de> wrote:
> > Hi,
> > to enable python bindings for debian I have following problems:
> > -- SIP is required in version 4.5 or later!
> > -- PyQt4 is needed in version 4.1 or later!
> > debian stable and testing includes PyQt4 4.0.1-5 and SIP 4.4.5-4. Wouldn't
that
> > be sufficient?
> > regards,
> > Otto
> > On Fri, 27 Jul 2007 13:50:53 -0300
> > "Tim Sutton" <tim at linfiniti.com> wrote:
> > > Hi All
> > > Today I've tagged 0.9.0 Preview 1 as per our release plan at
> > > http://wiki.qgis.org/qgiswiki/ReleaseChecklist0.9
> > > You can check out a copy doing:
> > > svn co https://svn.qgis.org/repos/qgis/tags/Preview-0.9.0-1
qgis0.9.0Preview1
> > > This should bring into effect the following things:
> > > - string freeze for UI - if you are a developer please dont change
> > > any more UI elements or translatable strings
> > > - call for translators to update ts files
> > > - call for document managers to update docs based on new features in SVN
> > > - call for packagers to create preview binaries
> > > A source bundle for preview 1 will be made available soon.
> > > Now is the time we call on your help to produce translations, update
> > > documentation etc. You dont need to be a programmer to be of
> > > assistance - all you need to do is be willing to donate some time and
> > > have a computer.
> > > Note that automake and qmake build systems are completely removed and
> > > using cmake is the only way to build QGIS 0.9.0 preview 1. Please see
> > > the INSTALL document in the source tree for detailed notes for your
> > > platform. http://wiki.qgis.org/qgiswiki/BuildingFromSource Also
> > > contains updated build notes for all platforms.
> > > Many thanks for all who are pitching in to make this release happen.
> > > Best regards
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
