[Qgis-developer] upgrading from 0.8.1 to 0.9
Martin Dobias wonder.sk at gmail.com
Sun Aug 5 13:25:36 EDT 2007
AFAIK there are no new library dependencies, neither need to upgrade
any libraries - in case you won't mind not having support for python
bindings. Their inclusion is optional, if used you'll need SIP >= 4.5
and PyQt >= 4.1
Martin
On 8/2/07, Sebastian Schmitz <sebastian.schmitz at wheregroup.com> wrote:
> Hi,
> we run QGIS 0.8.1 on a KNOPPIX (debian-based) liveCD.
> 0.8.1 still has a bug in georeferencing that is fixed in 0.9. Asking for
> someone to create a patch for 0.8.1 resulted in silence so far.
> The other feasible option would be to upgrade to 0.9. To what extent did
> library dependencies change from 0.8.1 to 0.9?
> Cheers
> Sebastian
> WhereGroup
> GmbH & Co. KG
> Siemensstr. 8
> D-53121 Bonn
> Amtsgericht Bonn, HRA 6788
> Fon: +49 (0)228 / 90 90 38 - 24
> Fax: +49 (0)228 / 90 90 38 - 11
> mailto:sebastian.schmitz at wheregroup.com
> http://www.wheregroup.com
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Arnulf Christl, Olaf Knopp, Peter Stamm
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
