[Qgis-developer] GRASS modules
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Tue Aug 14 14:30:59 EDT 2007
OK, I have attached my notes about trying to compile and run
QGIS 0.8.1 on Windows with Cygwin. It's messy (thanks to Windows)
to say the least.
But I managed to get everything to compile. However, trying to start
QGIS just resulted in a completely silent crash.
Maybe someone with more expertise on Windows C++ development could pick
it up from there and just get it to the point where QGIS (0.9?) starts
and runs with GRASS Cygwin.
I would then produce an up-to-date set of GRASS 6.3 binaries.
Benjamin
Tim Sutton wrote:
> Hi
> I hevent tried with cygwin - but if they prove to work reliably with
> QGIS and they are official GRASS products we should certainly consider
> using them as a drop in replacement for the ones we currently have in
> QGIS-win. To my mind it would be the most ideal situation if the QGIS
> folks were not trying to maintain a separate build of GRASS binaries -
> its a waste of effort and I think a source of numerous bugs and issues
> since we are not experts in GRASS.
> Tisham how will dropping in cygwin for you?
> Regards
> Tim
> 2007/8/11, Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de>:
>> Please also keep in mind silly bug #738 which basically
>> renders GRASS on native Win32 useless for any
>> professional level work involving vector attribute
>> data.
>> I have tried finding the cause of this for weeks,
>> but in vain. Guess my Win32 system API skills are
>> just not good enough.
>> Btw., Cygwin versions of current GRASS 6.3.cvs run
>> just fine.
>> Has anyone here ever tried to get QGIS 0.9 running
>> with Cygwin based GRASS binaries?
>> Benjamin
>> Paolo Cavallini wrote:
>>> Hi.
>>> Tim uploaded our new GRASS modules-thanks!
>>> Now QGISsers can do *a lot* of stuff with GRASS. Especially (but not
>>> only) for win users this is, I think, a big step forward.
>>> A couple of things remain to be fixed, however:
>>> - the very frequent crash while loading grass layers (a regression)
>>> - attribute fields are not shown in the module window
>>> I think these should be fixed before releasing 0.9.
>>> All the best.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.qgis.org
>>> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Installing GRASS 6.3.cvs with Cygwin on Win32
Everything works slower under Cygwin than native Win32, but the
unix environment provided but Cygwin is very complete and robust
so that it is easier to get things running the same as under
Linux.
The most detailed instructions about GRASS on Cygwin are still
here: [http://geni.ath.cx/grass.html]. Also, see this old Wiki
page with lots of hints: [http://geni.ath.cx/wiki_cygwin_grass.html]
The most up-to-date instructions and Cygwin packages are here: [http://grass.itc.it/grass62/binary/mswindows/]
These installation instructions are for users with administrator
privileges that can do system-wide installations of the software.
I have not tested this for restricted user accounts.
You will likely need a good text editor that can also handle Unix
EOL characters correctly. Download and install PSPad from [www.pspad.com]
. It will make your Windows life much easier!
TODO
⢠Explore the possibility to install Cygwin with normal user
privileges for current user only (setting ``Just Me'' in
Cygwin's setup.exe options).
⢠User home directory is per default in c:\cygwin\<username> but
this can be changed! Change it to the regular Windows home
folder? Problem: this has spaces!
⢠Add SQLite support: get sqlite.exe to compile!
⢠Test PostgreSQL support
⢠Add ODBC support (possible?)!
⢠Motif support for GRASS?
⢠MySQL support?
⢠Freetype support for GRASS.
⢠Python bindings for QGIS 0.8.1 (see INSTALL file in QGIS source
dir).
1 Cygwin Installation<sec:Cygwin-Installation>
Cygwin DLL version 1.5.24-2
1.1 Installing the base system
Download setup.exe from [www.cygwin.com] to ``inst''.
Run ``setup.exe''
Select ``Download without Installing'' and download packages to
directory ``inst\cygwin-packages''.
Adjust Internet Connection settings if necessary.
Choose a Download site (http://linux.rz.ruhr-uni-bochum.de).
In addition to the default selection, add these packages:
⢠Archive
â unzip
â zip
⢠Database
â postgresql
â postgresql-devel
⢠Devel
â autoconf
â automake 1.9
â binutils
â bison
â byacc
â cvs
â doxygen
â flex
â gcc
â gettext
â gettext-devel
â libfreetype2-devel
â libiconv-devel
â libncurses-devel
â libtool1.5
â libxml2
â libxml2-devel
â make
â nasm
â patchutils
â pcre
â pcre-devel
â pkg-config
â readline
â subversion
â swig
⢠Editors
â mc
â nano
â nedit
⢠Graphics
â ImageMagick
â gd
â ghostscript
â ghostscript-x11
â gnuplot
â jpeg
â libgd-devel
â libgeotiff
â libgeotiff-devel
â libproj-devel
â libtiff-devel
â netpbm
â proj
â tiff
⢠Interpreters
â python
⢠Libs
â gsl: Runtime
â gsl-devel
â libgdbm4
â ncurses
â popt
â sunrpc
⢠Math
â fftw3
â fftw3-dev
⢠Text
â gv
⢠Utils
â screen
⢠Web
â wget
Now download the packages. If the download should be incomplete:
it can be restarted from another source. The package selection
will be preserved.
Now run setup.exe again to install all downloaded packages:
Select ``Install from Local Directory''.
Next, choose the Installation Directory. A wise choice is
C:\cygwin (default). Make sure that ``Default Text File Type'' is
set to ``Unix/binary''.
Next, set the ``Local Package Directory'' to where the packages
where downloaded to ``inst\cygwin-packages''. Set the ``All''
category to ``Install''. All downloaded packages should now be
selected for installation. Install them! If the installer
recommends to install additional packages (dependencies): just
confirm.
The installation may take a few minutes as a lot of Unix software
will be installed.
Also add C:\cygwin\bin to the Windows Environment Variable ``Path''
. This way you will be able to run the many useful Cygwin Unix
tools from anywhere on the command line.
1.2 Updating and adding packages<sub:Updating-and-adding>
Just rerun setup.exe and select ``Download without installing''.
You will be able to download more packages. Then rerun setup.exe
again, this time ``Install from Local Directory'''' and make sure
to select the newly downloaded packages. Keep all other
installation setting (path!) the same: the new software will be
added to your installation.
Once you are done installing Cygwin, update the binutils (linker
and friends) if you plan to compile any software yourself. Create
a directory binutils, change into it, then do:
cvs -z 9 -d :pserver:anoncvs at sourceware.org:/cvs/src login
Enter "anoncvs" as the password.
cvs -z 9 -d :pserver:anoncvs at sourceware.org:/cvs/src co binutils
Compilation of binutils:
cd src
automake
./configure --prefix=/usr
make
make install
1.3 Cygwin usage hints
Nothing so far.
2 Installing GRASS and dependencies
UPDATE THE binutils PACKAGE (see [sub:Updating-and-adding])!!!
Otherwise linking GRASS' Vlib with the GDAL lib will fail!
All required source code packages need to be downloaded to the
Cygwin home directory of a user with admin privileges (if Cygwin
has been setup for system-wide usage).
Windows only looks for shared libraries (DLLs) in executable file
directories or in the same directory where the application was
started! This is a heavy design flaw that Cygwin is unfortunately
also subjected to. So remember to copy compiled DLLs (e.g. GDAL!)
to /usr/bin as well!! If some program just dies w/o any error
message, it's usually because of some DLL that's not in the path.
You can use cygcheck.exe <program> to test for such problems.
The C compiler supplied by Cygwin is GCC version 3.4.4.
2.0.1 SQLite
TODO: does not work yet (see below), so for now no SQLite
support!
Version 3.4.0 from [http://www.sqlite.org].
SQLite only works as a static lib under Cygwin and the
configuration script is a bit buggy:
./configure --prefix=/usr --disable-tcl
make
Warning appears:
libtool: link: warning: undefined symbols not allowed in
i686-pc-cygwin shared libraries
Even though shared libraries were disabled in the configure
script!
This leads to a failure when attempting:
make install
Error message:
It is possible to produce the sqlite3 shared lib, however:
make clean
make sqlite3.dll
cp sqlite3.dll /usr/bin/
Copy DLLs to /usr/bin (see general notes at start of this
section) as well!
We also need to copy the C development headers by hand:
cp *.h /usr/include
Now we have all we need from SQLite in order to compile GRASS and
QGIS. Unfortunately, the command line program to manage an SQLite
database (sqlite.exe) is missing. But might be possible to
download and use the Windows binary for sqlite.exe from the
SQLite homepage!
2.1 UnixODBC
Tested version 2.2.12 from u[www.unixodbc.org]:
./configure --prefix=/usr --disable-gui
make
Aborts with:
gcc -g -O2 -DENABLE_INI_CACHING -o isql.exe isql.o
../DriverManager/.libs/libodbc.a -ldl /usr/lib/libiconv.dll.a
../extras/.libs/libodbce
dline -lpthread
isql.o: In function `OptimalDisplayWidth':
/home/Administrator/unixODBC-2.2.12/exe/isql.c:236: undefined
reference to `_SQLColAttribute'
/home/Administrator/unixODBC-2.2.12/exe/isql.c:237: undefined
2.1.1 GEOS
Version 2.2.3
Get it from [http://geos.refractions.net/].
make
make install
2.1.2 GDAL<sub:GDAL>
Upddate the binutils PACKAGE (see [sub:Updating-and-adding])!!!
Version 1.4.2 (and gdal-grass 1.4.1) from [www.gdal.org].
Install GDAL w/o GRASS support. Some configure options need to be
set to produce shared DLL libraries:
./configure --prefix=/usr --enable-shared=yes --without-libtool
--without-python
IMPORTANT: Make sure you do not create a static version of GDAL
by accident. If there is a libgdal.a lying around in /usr/lib
already: make sure to delete it, otherwise, you probably not even
be able to configure GRASS correctly!
This should enable support for PostgreSQL and GEOS but not GRASS.
GRASS support will be enabled later using gdal-grass.
make
make install
Make a copy of libgdal.dll.1.4.2 and call it libgdal.dll.
section)!
2.1.3 GRASS 6.3.CVS
We need a GRASS version that runs w/o X11 and Tcl/Tk so we have a
GUI-independent core that we can connect with QGIS.
For GRASS, we use latest CVS sources (Fri, July 13th 2007), as
these are most extensively modified to work on Windows.
Change into home dir.
touch .cvspass
export
CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository
cvs login
Password is 'grass'.
cvs -z3 checkout grass6
This will put the most recent sources into the directory grass6.
Subsequent updates:
cvs up -dP
We cannot configure GRASS w/o GDAL anymore, as GDAL is now a
mandatory lib.
Change into grass6 source directory.
./configure --with-readline --without-nls
(NLS enables language localizations resulting in horrible GUI
strings.)
This should enable pretty much the full GRASS feature set
(except: see TODO section at top of this document. Also BLAS and
a few more things are missing that are useless, anyway).
make
This should create all enabled modules currently in CVS w/o
compilation errors!
make install
will put everything into /usr/local/grass-6.3.cvs inside your
Cygwin install directory.
Now we need to install the GRASS driver for GDAL. Version 1.4.1
of gdal-grass should work fine:
./configure --with-grass=/usr/local/grass-6.3.cvs/
--with-gdal=/usr/bin/gdal-config --prefix=/usr
make
make install
This concludes the basic GRASS setup.
2.2 Cygwin tuning
Make a copy of c:\cygwin\usr\X11R6\bin\startxwin.bat as
c:\cygwin\GRASS.bat.
change
%RUN% xterm -e /usr/bin/bash -l
to
%RUN% xterm -e /usr/local/bin/grass63
The X server will keep running after GRASS was exited. However,
this just gives an annoying error message when running GRASS.bat
again without first manually quitting the X server.
2.3 Bugs and pitfalls
⢠MAJOR BUG: Resizing an X monitor sends it into an endless ``
Redraw'' sleep state (but only if some d.* was sent to it
before). However, gis.m monitors work.
⢠The instructions assume that Cygwin is installed in C:.
⢠It does not seem to go well to have two different versions of
Cygwin running on the same machine.
⢠Many problems with the Tcl/Tk login GUI
â The TclTk login screen complains about ``invalid mapsets'' if
the location is stored on a network drive and there are
permission problems (?). However, text login works fine.
â Clicking on ``Exit'' in the TclTk login GUI still starts
GRASS!
â Clicking on ``Projection Values'' to define a new Location
just gives an error message ``Invalid switch -''/usr''''. The
problem originates from this line:
exec -- cmd.exe /c start $env(GISBASE)/etc/set_data
in the file etc/gis_set.tcl. Apparently, the ``start'' command
interpretes the GRASS installation path as a command switch
because of the leading ``/''!
HOTFIX: replace with
exec -- xterm.exe -e $env(GISBASE)/etc/set_data
â This line is actually meant for MINGW GRASS! It wrongly
assumes that Cygwin GRASS works just the same, so this fix
cannot go into CVS. Instead, we must differentiate between
MINGW and Cygwin here.
â Also, the set_data text screen checks for the path of the
database starting with ``/''. This makes sense on a Unix
system, but in the case of Cygwin it just forces uses to
learn about the /cygdrive/drive# convention, which is a
nuissance.
⢠Browsing documentation: not clear how to invoke the system's
HTML browser. For now, users can just open the local index.html
file with their favourite browser.
2.4 TODO
⢠Get NVIZ to work:
â nviz lives in etc/nviz2.2/nviz.exe. However, there is also an
nviz.bat in bin!
â complains about not being able to find init.tcl in a (pretty
dumb) searchpatch. Linking /usr/share to /share helps, but
nviz still crashes after showing some initial GUI elements.
Cygcheck
â nviz.bat complains: ``The system cannot find the path
specified''
⢠Compile with SQLite support.
⢠Compile with UnixODBC support.
⢠Compile with MySQL support.
3 QGIS with Cygwin GRASS
This is really tricky. Basically because Windows is a horribly
designed operating system with minimal support for standards such
as Posix and compilation of complex software is a nightmare. The
problem is that we need to compile a mix of Cygwin libraries
(i.e. with a Unix emulation layer that includes sockets etc.) and
``pure'' Win32 API and C runtime. It can be done but you must pay
attention to every detail as described below.
QGIS and Qt4 are compilable on Windows using the free MinGW. As
opposed to Cygwin, MinGW just links binaries to the original
Win32 runtime libraries. It does not provide a Unix emulation
layer like Cygwin does.
3.1 Preparations
Download QGIS 0.8.1 sources from www.qgis.org. Unpack the sources
into your Cygwin home folder. The INSTALL file has notes about
compilation on Windows using MingW.
Download the Qt open source edition for Windows including MinGW
from here: [http://trolltech.com/developer/downloads/qt/windows].
Run the installer and install the Qt software (default:
C:\Qt\4.3.0). Select to download and install MinGW into c:\MinGW.
This installs a version of MinGW that Qt is sure to work with.
To make your life easier, also download and install MSYS
(1.0.11-2004.04.30-1.exe) from [www.ming.org] and install to the
directory C:\msys. The install script will try to ``normalize''
your MinGW environment. Just answer ``y'' and supply the path to
your MinGW installation (c:\MinGW). NOTE: You need to remove or
(better) rename sh.exe (the Unix shell) in C:\msys\bin as this
will interfere with the CMake build process later!
To complete the MinGW environment, you need the flex and bison
utilities. THEORETICALLY, they should be availabe here: [http://sourceforge.net/project/showfiles.php?group_id=2435&package_id=82724]
. THEORETICALLY, you should just have to download the packages,
unpack (e.g. with [www.izarc.com]) and add the contained files to
the same folders (bin, lib, ...) in your MSYS directory (not
MinGW!). BUT THIS WON'T WORK!
The problem is that bison will not find its macro definitions and
always spit out a message like this:
/msys/share/bison/m4sugar/m4sugar.m4': No such file or directory
Bison only works if you start MSYS via it's own startup script
msys.bat. This will set the path correctly. HOWEVER, this will
also attempt to start sh.exe and since we can't allow that (see
above), we are f*****!
The current solution is a bit awkward: rename Cygwin's shell
(c:\cygwin\sh.exe) to sh.org, then finish the QGIS compilation
process, afterwars rename it to sh.exe again to get it working
again (sorry...).
For compilation to work, we must add some folders to the Windows
PATH environment, so linking to DLLs can be done. Edit
C:\Qt\4.3.0\bin\qtvars.bat and add the following line to the
sequence of ``set PATH'' statements (in this order!):
set PATH=%PATH%;C:\MinGW\bin;C:\cygwin\bin
set PATH=%PATH%;c:\cygwin\lib
set PATH=%PATH%;C:\cygwin\usr\local\grass-6.3.cvs\lib
Also add C:\Qt\4.3.0\bin to the Windows Environment Variable ``
Path''. This will make it easier to run the basic Qt tools from
anywhere.
You can skip all the other tools mentioned in the QGIS INSTALL
file as you already have the Cygwin versions of these available
at this point.
Now we need Cmake, a tool to configure multi platform source
codes that is needed by QGIS. Download from [http://www.cmake.org/files/v2.4/cmake-2.4.6-win32-x86.exe]
and install. The installer suggests a path with spaces by
default, so you might want to change this to something more
simple like c:\cmake just ot be on the safe side. This is a
special Windows version with GUI. Let the installer add it to the
system PATH if you like.
Again, edit C:\Qt\4.3.0\bin\qtvars.bat and add the following line
to the sequence of ``set PATH'' statements (adjust path if you
chose to install Cmake somewhere else):
set PATH=%PATH%;"C:\Program Files\cmake\bin"
3.2 Compilation of QGIS
Start a regular Windows command line (cmd.exe). Then cd into your
Cygwin home dir and to the dir where you have previously
downloaded and unpacked the QGIS 0.8.1 sources.
Execute qtvars.bat to set environment variables correctly.
Configure the source: create a directory for the build inside the
QGIS source dir and change into it. Then run CMake:
md build
cd build
cmakesetup ..
The GUI should show correct source and build dirs. Press ``
Configure'' and choose ``MinGW Makefile'' (works on Windows XP;
use ``MSYS Makefile'' for Windows 2000).
The configuration should find everything OK except some libraries
and include files which are in the Cygwin dir and must be
specified manually (SELECT ``Show Advanced Values!''):
BISON_EXECUTABLE = C:/cygwin/bin/bison.exe
CMAKE_CXX_COMPILER = C:/MinGW/bin/g++.exe
CMAKE_CXX_FLAGS = '-Ic:/MinGW/include'
CMAKE_C_COMPILER = C:/MinGW/bin/gcc.exe
CMAKE_C_FLAGS = '-Ic:/MinGW/include'
CMAKE_EXE_LINKER_FLAGS = '-Lc:/MingW/lib'
CMAKE_MAKE_PROGRAM = C:/MinGW/mingw32-make.exe
CMAKE_MODULE_LINKER_FLAGS = '-Lc:/MingW/lib'
CMAKE_SHARED_LINKER_FLAGS = '-Lc:/MingW/lib'
FLEX_EXECUTABLE = C:/msys/bin/flex.exe
GDAL_INCLUDE_DIR = C:/cygwin/usr/include
GDAL_LIBRARY = C:/cygwin/lib/libgdal.dll
GEOS_INCLUDE_DIR = C:/cygwin/usr/include
GRASS_PREFIX = C:/cygwin/usr/local/grass-6.3.cvs
PROJ_INCLUDE_DIR = C:/cygwin/usr/include
SQLITE_INCLUDE_DIR = C:/cygwin/usr/include
Press ``Configure'' again. Some more dependencies will not be
found and must be set manually:
EXPAT_INCLUDE_DIR = C:/cygwin/usr/include
GSL_INCLUDE_DIR = C:/cygwin/usr/include/gsl
GSL_PREFIX = C:/cygwin/usr
POSTGRES_INCLUDE_DIR = C:/cygwin/usr/include
Press ``Configure'' again. There should be no more missing
critical dependencies. Make sure that:
WITH_BINDINGS = OFF (Python disabled for now)
WITH_GRASS = ON
Select ``OK''. When the configuration is done, compile and
install with:
make
make install
Create a folder grass in the qgis install dir. Copy all files
from the GRASS installation compiled under Cygwin (located in
/usr/local/grass-6.3.cvs) in there. Move all files from the
grass/lib directory into the QGIS main installation dir so
Windows will find them.
Copy GDAL DLLs and executables from the Cygwin installation into
the QGIS main dir:
proj.exe:
Copy Cygwin DLLs (from c:\cygwin\bin) into the QGIS main dir:
cyggeos-2.dll
cygwin1.dll
cygproj-0.dll
cygpq.dll
cygcrypt-0.dll
cygcrypt-0.9.8.dll
cygintl-3.dll
cygiconv-2.dll
cygssl-0.9.8.dll
libgdal.dll
cyggeos_c-1.dll
cyggeotiff-1.dll
cygtiff-5.dll
cygz.dll
cygjpeg-62.dll
cygjasper-1-701.dll
cygpng12.dll
cygintl-8.dll
sqlite3.dll
Also, remember to rename Cygwin's sh.org back to sh.exe so you
will have a shell to work with!
