[Qgis-developer] comments on qgsvectorlayer.cpp
Albert Cervera i Areny albert at nan-tic.com
Thu Aug 30 19:22:48 EDT 2007
Recently I've been taking a look a the vector layer source code and trying to
find with the help of valgrind and kcachegrind where most of the time was
spent. With the files I took I started playing a bit and it seemed that most
time was spent in the drawPolygon function. Not a big surprise given the
sample data, but a good place to start.
	I looked at it and tried to redo some things to find if I could do something
to improve performance. The result, no performance gain, at least no user
perceivable difference, but the code seemed much clearer because path is
filled in the first loop. However, to achieve that I removed the code
responsible for clipping values that don't fit into 16-bit signed values as
it seems that was a Qt 3 limitation and Qt4 possibly has an internal
solution/workaround for that. (At least I see no warnings in Qt4 docs). If
that code is correct, then something similar could be done for drawLineString
and drawFeature.
	Please, see attached a diff for current trunk. Of course that's working fine
in my tests.
	By the way, as I said what I wanted to find is a way to improve performance.
For example with the map of spain I've been playing it takes 4 seconds to
repaint the hole map with 3 layers (1 with polygons and a couple with lines).
Looking at the code a possible solution that comes to mind would be to try to
keep the generated polygon (or line or whatever) path from one call to
another, maybe adding polygons in the path on demand when the user moves. I
imagine that would mean redesigning the the way zooming and scrolling is
handled. But probably I'm also ignoring many other aspects, as I've only
worked with a very little part of the source code.
	Any way, I was interested in knowing how it all worked and try to find out if
there've been some discussions regarding theses performance issues.
	Comments?
http://www.NaN-tic.com
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20070831/21e9fe4f/qgsvectorlayer.cpp.bin
