[Qgis-developer] DBMS support for Win32
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Tue Dec 11 03:58:42 EST 2007
FWIW, I have attached all my notes on how to get support for
SQLite, MySQL, PostgreSQL and ODBC into GDAL and GRASS using MinGW.
I don't know whether all of this is optimal, but it works
for me.
If you find anything wrong or missing in the instructions, please
let me know.
Benjamin
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
1. COMPILING DBMS DRIVERS
**** ODBC ****
ODBC support is part of the standard Win32 functionality. A recent version of MinGW's Win32 API should have the necessary header file sql.h. In addition, you need to copy over odbc32.dll to a location where the MSYS shell and the GRASS configure script can see it. On a Windows 2000 system, the library we need is located in C:\WINNT\system32. On XP it is in C:\Windows\system32.
You also need to rename the library to odbc.dll so the GRASS and GDAL configure scripts will detect it. E.g., on a Windows 2000 system, do:
cp /c/WINNT/system32/odbc32.dll /usr/lib/odbc.dll
cp /c/WINNT/system32/odbc32.dll /usr/lib/odbcinst.dll
Note: In order to correctly parse the declarations in the odbc header files (sqltype.h, etc.), the file /mingw/include/windows.h needs to be included in every source file that uses ODBC function calls (especially important for GRASS ODBC support: see notes in ).
Note: Windows' own odbc32.dll is not free software and cannot be re-distributed freely! This should not be necessary, however, as every Windows installation should come with a copy of it. To make sure you do not accidentally re-distribute a copy, you may want to delete odbc.dll from /usr/lib after you have finished linking your software to it.
**** PostgreSQL 8.2.5 ****
Download the file postgresql-8.2.5.tar.bz2 from  and save in the source folder.
cd /src
tar -xjf postgresql-8.2.5.tar.bz2
cd postgresql-8.2.5
In file src/include/port.h: Comment out or delete the line with the definition of the function gettimeofday().
In file src/include/port/win32.h: Comment out or delete the entire definition of struct timezone{}.
In file src/port/gettimeofday.c: Rename the function gettimeofday() to gettimeofday2().
Now continue:
./configure --prefix=/usr --with-libs=/usr/lib --with-includes=/usr/include --bindir=/usr/local/bin --with-openssl
make
make install
cp /usr/lib/*.dl* /usr/local/bin/
cp /usr/lib/postgresql/*.dll /usr/local/bin/ -R
**** SQLite 3.5.1 ****
SQLite is a drop-in replacement for DBF as a file-based attribute data storage that is more flexible and less limited (e.g. no 2GB maximum file size limit).
Download sqlite-3.5.1.tar.gz from  and save it into the source directory.
cd /src
tar -xzvf sqlite-3.5.1.tar.gz
cd sqlite-3.5.1
./configure --bindir=/usr/local/bin --prefix=/usr --disable-static --enable-shared
make
We now need to create the DLL files for Win32 and install all neded binaries and header files manually, as the ``make install'' fails for various reasons with MinGW:
make sqlite3.dll
cp sqlite3.dll /usr/lib/libsqlite3.dll
cp sqlite3.h /usr/include
cp sqlite3.exe /usr/local/bin
**** MySQL 5.0.45 from Binaries ****
Download the file mysql-noinstall-5.0.45-win32.zip from  and save it to any folder.
Uncompress the zip files contents, below the top level directory mysql-5.0.45-win32, to C:\msys\1.0\local\mysql, so that the subfolders bin, data, Docs, etc. go directly into C:\msys\1.0\local\mysql.
In order to get headers and DLLs to work with MinGW, a few adjustments are needed.
First, the libmysql.def file shipped with the MySQL binaries is missing mangled function names which the MinGW linker needs. Open the file C:\msys\1.0\local\mysql\include\libmysql.def in a text editor and make sure it has the following content:
LIBRARY         LIBMYSQL
VERSION         6.0
EXPORTS
        _dig_vec_lower
        _dig_vec_upper
        bmove_upp
        delete_dynamic
        free_defaults
        getopt_compare_strings
        getopt_ull_limit_value
        handle_options
        init_dynamic_array
        insert_dynamic
        int2str
        is_prefix
        list_add
        list_delete
        load_defaults
        my_end
        my_getopt_print_errors
        my_init
        my_malloc
        my_memdup
        my_no_flags_free
        my_path
        mysql_get_parameters
        my_print_help
        my_print_variables
        my_realloc
        my_strdup
        mysql_thread_end
        mysql_thread_init
        myodbc_remove_escape
        mysql_affected_rows
        mysql_autocommit
        mysql_stmt_bind_param
        mysql_stmt_bind_result
        mysql_change_user
        mysql_character_set_name
        mysql_close
        mysql_commit
        mysql_data_seek
        mysql_debug
        mysql_dump_debug_info
        mysql_eof
        mysql_errno
        mysql_error
        mysql_escape_string
        mysql_hex_string
        mysql_stmt_execute
        mysql_stmt_fetch
        mysql_stmt_fetch_column
        mysql_fetch_field
        mysql_fetch_field_direct
        mysql_fetch_fields
        mysql_fetch_lengths
        mysql_fetch_row
        mysql_field_count
        mysql_field_seek
        mysql_field_tell
        mysql_free_result
        mysql_get_client_info
        mysql_get_host_info
        mysql_get_proto_info
        mysql_get_server_info
        mysql_get_client_version
        mysql_get_ssl_cipher
        mysql_info
        mysql_init
        mysql_insert_id
        mysql_kill
        mysql_set_server_option
        mysql_list_dbs
        mysql_list_fields
        mysql_list_processes
        mysql_list_tables
        mysql_more_results
        mysql_next_result
        mysql_num_fields
        mysql_num_rows
        mysql_odbc_escape_string
        mysql_options
        mysql_stmt_param_count
        mysql_stmt_param_metadata
        mysql_ping
        mysql_stmt_result_metadata
        mysql_query
        mysql_read_query_result
        mysql_real_connect
        mysql_real_escape_string
        mysql_real_query
        mysql_refresh
        mysql_rollback
        mysql_row_seek
        mysql_row_tell
        mysql_select_db
        mysql_stmt_send_long_data
        mysql_send_query
        mysql_shutdown
        mysql_ssl_set
        mysql_stat
        mysql_stmt_affected_rows
        mysql_stmt_close
        mysql_stmt_reset
        mysql_stmt_data_seek
        mysql_stmt_errno
        mysql_stmt_error
        mysql_stmt_free_result
        mysql_stmt_num_rows
        mysql_stmt_row_seek
        mysql_stmt_row_tell
        mysql_stmt_store_result
        mysql_store_result
        mysql_thread_id
        mysql_thread_safe
        mysql_use_result
        mysql_warning_count
        mysql_stmt_sqlstate
        mysql_sqlstate
        mysql_get_server_version
        set_dynamic
        strcend
        strcont
        strdup_root
        strfill
        strinstr
        strmake
        strmov
        strxmov
        mysql_stmt_prepare
        mysql_stmt_init
        mysql_stmt_insert_id
        mysql_stmt_attr_get
        mysql_stmt_attr_set
        mysql_stmt_field_count
        client_errors
        mysql_set_local_infile_default
        mysql_set_local_infile_handler
        mysql_disable_reads_from_master
        mysql_disable_rpl_parse
        mysql_enable_reads_from_master
        mysql_enable_rpl_parse
        mysql_master_query
        mysql_rpl_parse_enabled
        mysql_rpl_probe
        mysql_rpl_query_type
        mysql_slave_query
        mysql_embedded
        mysql_server_init
        mysql_server_end
        mysql_set_character_set
        mysql_get_character_set_info
        get_defaults_options
        modify_defaults_file
      mysql_affected_rows at 4
      mysql_close at 4
      mysql_error at 4
      mysql_escape_string at 12
      mysql_fetch_fields at 4
      mysql_fetch_lengths at 4
      mysql_fetch_row at 4
      mysql_free_result at 4
      mysql_init at 4
      mysql_num_fields at 4
      mysql_options at 12
      mysql_query at 8
      mysql_real_connect at 32
      mysql_real_escape_string at 16
      mysql_stmt_bind_param at 8
      mysql_stmt_bind_result at 8
      mysql_stmt_close at 4
      mysql_stmt_error at 4
      mysql_stmt_execute at 4
      mysql_stmt_fetch at 4
      mysql_stmt_free_result at 4
      mysql_stmt_init at 4
      mysql_stmt_param_count at 4
      mysql_stmt_prepare at 12
      mysql_stmt_result_metadata at 4
      mysql_stmt_store_result at 4
      mysql_store_result at 4
      mysql_use_result at 4
      myodbc_remove_escape at 8
      mysql_autocommit at 8
      mysql_change_user at 16
      mysql_character_set_name at 4
      mysql_commit at 4
      mysql_connect
      mysql_create_db
      mysql_debug at 4
      mysql_dump_debug_info at 4
      mysql_eof at 4
      mysql_fetch_field at 4
      mysql_fetch_field_direct at 8
      mysql_field_count at 4
      mysql_field_seek at 8
      mysql_field_tell at 4
      mysql_get_client_info at 0
      mysql_get_client_version at 0
      mysql_get_host_info at 4
      mysql_get_proto_info at 4
      mysql_get_server_info at 4
      mysql_get_server_version at 4
      mysql_hex_string at 12
      mysql_kill at 8
      mysql_list_dbs at 8
      mysql_list_fields at 12
      mysql_list_processes at 4
      mysql_list_tables at 8
      mysql_more_results at 4
      mysql_next_result at 4
      mysql_num_rows at 4
      mysql_ping at 4
      mysql_real_query at 12
      mysql_rollback at 4
      mysql_row_tell at 4
      mysql_select_db at 8
      mysql_set_server_option at 8
      mysql_shutdown at 8
      mysql_sqlstate at 4
      mysql_ssl_set at 24
      mysql_stat at 4
      mysql_stmt_affected_rows at 4
      mysql_stmt_attr_get at 12
      mysql_stmt_attr_set at 12
      mysql_stmt_data_seek at 12
      mysql_stmt_errno at 4
      mysql_stmt_fetch_column at 16
      mysql_stmt_field_count at 4
      mysql_stmt_insert_id at 4
      mysql_stmt_num_rows at 4
      mysql_stmt_param_metadata at 4
      mysql_stmt_reset at 4
      mysql_stmt_row_seek at 8
      mysql_stmt_row_tell at 4
      mysql_stmt_send_long_data at 16
      mysql_stmt_sqlstate at 4
      mysql_thread_end at 0
      mysql_thread_id at 4
      mysql_thread_init at 0
      mysql_thread_safe at 0
      mysql_warning_count at 4
      mysql_errno at 4
      mysql_insert_id at 4
Now, re-generate the libraries:
cd /usr/local/mysql
dlltool --input-def include/libmySQL.def --dllname bin/libmysql.dll --output-lib bin/libmysqlclient.a -k
You need to adjust some lines in C:\msys\1.0\local\mysql\include\mysql.h. Locate the paragraph that reads:
#ifndef my_socket_defined
#ifdef __WIN__
#define my_socket SOCKET
#else
typedef int my_socket;
#endif /* __WIN__ */
#endif /* my_socket_defined */
#endif /* _global_h */
And change it to:
#ifdef __WIN__
In C:\msys\1.0\etc\profile, extend the system path to include the MySQL programs:
export PATH="$PATH:/usr/local/mysql/bin:/usr/local/mysql/scripts"
Unfortunately, we need to do a little more clean-up work so that other software will be able to link to the MySQL libraries later.
Open the file C:\msys\local\mysql\include\config-win.h in a text editor.
Remove the entire code block that re-defines the function ``rint'' (ca. lines 227-232):
inline double rint(double nr)
  double f = floor(nr);
  double c = ceil(nr);
  return (((c-nr) >= (nr-f)) ? f :c);
Remove the line (ca. 453) that re-defines the function ``popen'':
#define popen(A,B) _popen((A),(B))
Next, open the C:\msys\local\mysql\scripts\mysql_config in a text editor. This script tells other programs where to find MySQL libraries and include files. We need to fill in some information manually. Locate the lines that define the items ``pkglibdir'', ``pkgincludedir'', ``cflags'' and ``libs'' and change them to the following:
pkglibdir='/usr/local/mysql/bin'
pkgincludedir='/usr/local/mysql/include'
cflags="-I$pkgincludedir " #note: end space!
libs="-L$pkglibdir -lz -leay32 -lssleay32 -lmysql"
2. CONFIGURING GRASS
./configure --with-includes=/usr/include --with-libs=/usr/lib --enable-shared=yes --with-opengl=windows --with-curses --with-cxx --without-fftw --with-mysql --with-mysql-includes=/usr/local/mysql/include --with-mysql-libs=/usr/local/mysql/bin/ --with-odbc --with-postgres --with-sqlite --without-x11
