[Qgis-developer] Patch for screen updates during long rendering
operations
Hugentobler Marco
marco.hugentobler at karto.baug.ethz.ch
Mon Dec 17 02:09:59 EST 2007
Hi Tom,
Thanks for looking into this. I'm curious what might be the cause of the different behaviour on Mac. On Thursday, I may also test the patch on a windows box (and probably on Mac too).
cheers,
Marco
-----Ursprüngliche Nachricht-----
Von: Tom Elwertowski [mailto:telwertowski at comcast.net]
Gesendet: So 16.12.2007 06:48
An: Hugentobler Marco
Cc: qgis-developer at lists.qgis.org
Betreff: Re: [Qgis-developer] Patch for screen updates during long rendering operations
Hi Marco,
The WMS resize optimization doesn't work on a Mac. When I resize a WMS
layer, the image is repeatedly fetched and the window slowly grows by
one pixel increments. The problem doesn't happen on Ubuntu. When I
resize the same layer there, the intermediate redraws are skipped.
One improvement is that newer redraws no longer interrupt the draw in
progress so the screen corruption during resizing is gone.
I will look for the cause of the extra redraws sometime in the next few
days.
Another difference is that if I maximize the window on a Mac with
incremental update enabled, the window resize does not happen until
after the redraw. First the map view grows and the maximized map is
incrementally rendered while the full view is not visible. Only at the
end does the window expand and the map becomes fully visible without
additional redrawing. On Ubuntu, it works more as expected. The window
expands first and then the map is incrementally rendered into the
enlarged and fully visible view.
Tom
