[Qgis-developer] Pre-Final Windows Build available
Otto Dassau
otto.dassau at gmx.de
Mon Dec 17 09:29:58 EST 2007
also also tested succesfully with sqlite and with postgres.
thanks a lot Tisham
Otto
On Mon, 17 Dec 2007 11:30:19 +0100
Leonardo Lami <lami at faunalia.it> wrote:
> tisham at apogee.com.au ha scritto:
> > Hi All,
> > I have made 1 away from final build today , it is available here.
> > http://whatnick.dyndns.org:8080/tisham/qgis_setup0.9.1.15_12_2007.exe
> > I solved a lot of the issues with gdal,xerces,sqlite,mysql etc on
> > MingW. I have also tested the SQlite driver and it works with grass.
> > Let me know if you want me to make up a tutorial on how to use it.
> > Regards,
> > Tisham,
> Hi Tisham,
> very good work for this update and I see also the QGIS-GRASS tutorial!
> I tested the pre-final build and I tested the SQLite driver that works well.
> Only a bug I see in this preview, when I run QGIS it say: "Couldn't load
> PyQT bindings. Python support will be disabled"
> The problem is that I have Python 2.5 installed in my computer with
> python-site-packages inserted in the C:/Python25/Lib/site-packages
> And If I run an old version of QGIS (0.9), it see the PyQt bindings and
> the Python plugins work.
> Something is changed in version of PyQt or in the searching path or
> other else?
> Thank you again for your good work
> Leonardo
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
