[Qgis-developer] QGIS and platforms
Tom Russo
tom.km5vy at gmail.com
Thu Feb 1 18:58:06 EST 2007
On 2/1/07, Martin Dobias <wonder.sk at gmail.com> wrote:
> Newer versions (I've looked into 2.4.6) use qmake's QMAKE_LIBS_THREAD
> variable to find this out. Please try this:
> - create a file, e.g. x.pro with this content:
> message($${QMAKE_LIBS_THREAD})
> - run: qmake x.pro
> - it should report the threading library which will be use, for me it shows:
> Project MESSAGE: -lpthread
No joy.
$ cat > x.pro
<control-D>
$ /usr/local/Trolltech/Qt-4.2.2/bin/qmake x.pro
Project MESSAGE:
My cmake is direct from the FreeBSD ports collection, which is installing 2.4.4
My Qt-4.2.2 is built from source, because QT4 isn't in the BSD ports
collection at all.
I configured and built it with no special options.
Looking in my FindQt4.cmake for something like what you posted I find
no block that's like that, and no "IF(UNIX)". But I do find this:
# configuration/system dependent settings
SET(QT_GUI_LIB_DEPENDENCIES "")
SET(QT_CORE_LIB_DEPENDENCIES "")
[many more lines deleted]
IF(Q_WS_X11)
# X11 libraries Qt absolutely depends on
QT_QUERY_QMAKE(QT_LIBS_X11 "QMAKE_LIBS_X11")
SEPARATE_ARGUMENTS(QT_LIBS_X11)
FOREACH(QT_X11_LIB ${QT_LIBS_X11})
STRING(REGEX REPLACE "-l" "" QT_X11_LIB "${QT_X11_LIB}")
SET(QT_TMP_STR "QT_X11_${QT_X11_LIB}_LIBRARY")
FIND_LIBRARY(${QT_TMP_STR} NAMES "${QT_X11_LIB}" PATHS ${QMAKE_LIBDIR_X11}
SET(QT_GUI_LIB_DEPENDENCIES ${QT_GUI_LIB_DEPENDENCIES} ${${QT_TMP_STR}})
ENDFOREACH(QT_X11_LIB)
QT_QUERY_QMAKE(QT_LIBS_THREAD "QMAKE_LIBS_THREAD")
SET(QT_CORE_LIB_DEPENDENCIES ${QT_CORE_LIB_DEPENDENCIES} ${QT_LIBS_THREAD})
QT_QUERY_QMAKE(QMAKE_LIBS_DYNLOAD "QMAKE_LIBS_DYNLOAD")
SET (QT_CORE_LIB_DEPENDENCIES ${QT_CORE_LIB_DEPENDENCIES} ${QMAKE_LIBS_DYNLO
AD})
ENDIF(Q_WS_X11)
That does sure look like it's trying to get the QMAKE_LIBS_THREAD
stuff out of qmake, but isn't getting anything.
Strange, though, I've tried to augment your "x.pro" file with an
additional message:
message($${QT_X11_LIB})
and that, too, prints nothing but "Project MESSAGE:". I'm suspicious of that.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
