[Qgis-developer] Mac OSX - Clean machine setup issues
Tim Sutton
tim at linfiniti.com
Sun Feb 4 13:04:01 EST 2007
I think it must be able to since its using framworks for Qt
stuff...not sure how to configure that though...
Regards
Tim
On 2/4/07, William Kyngesburye <woklist at kyngchaos.com> wrote:
> I wonder if cmake can handle -framework flags, then it would be even
> simpler to have that as an option (but leave a unix gdal-config
> option as a choice). Have it use:
> -framework GDAL
> instead of checking with gdal-config or hardcoding paths. Same for
> other of my frameworks used in Qgis. A choice of unix-style dylibs
> or Mac frameworks, if available.
> On Feb 4, 2007, at 6:13 AM, Martin Dobias wrote:
> > I've added the paths so you shouldn't need to specify GSL_CONFIG,
> > GDAL_CONFIG and GRASS_PREFIX on Mac anymore.
> > Martin
> > On 2/4/07, Tim Sutton <tim at linfiniti.com> wrote:
> >> Hi
> >> Yes I think this would be a good idea since my wiki docs (which will
> >> hopefully becme the official guide for buildng on mac) make use of
> >> williams gis frameworks which I think make sense for anyone
> >> considering building on mac to use. Even adding GRASS.app path might
> >> not be a bad idea.
> >> Regards
> >> Tim
> >> > > tims-computer:~/dev/cpp/qgis/build tim$ cmake -D
> >> > > CMAKE_INSTALL_PREFIX=/Users/tim/apps/ -D
> >> > > GDAL_CONFIG=/Library/Frameworks/GDAL.framework/unix/bin/gdal-
> >> config -D
> >> > > GRASS_PREFIX=/Applications/GRASS.app/Contents/Resources -D
> >> > > GSL_CONFIG=/usr/local/bin/gsl-config -D WITH_BINDINGS=ON -D
> >> > > WITH_GRASS=ON ..
> >> > Hi,
> >> > in case that these paths are somewhat "default" for Mac, it's no
> >> > problem to them to add them to detection routines... as I see at
> >> least
> >> > /usr/local should be supported for GSL, what about the others -
> >> > GDAL_CONFIG and GRASS_PREFIX ?
> >> > Martin
> >> Tim Sutton
> >> Visit http://qgis.org for a great Open Source GIS
> >> Home Page: http://linfiniti.com
> >> Skype: timlinux
> >> MSN: tim_bdworld at msn.com
> >> Yahoo: tim_bdworld at yahoo.com
> >> Jabber: timlinux
> >> Irc: timlinux on #qgis at freenode.net
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "Mon Dieu! but they are all alike. Cheating, murdering, lying,
> fighting, and all for things that the beasts of the jungle would not
> deign to possess - money to purchase the effeminate pleasures of
> weaklings. And yet withal bound down by silly customs that make them
> slaves to their unhappy lot while firm in the belief that they be the
> lords of creation enjoying the only real pleasures of existence....
> - the wisdom of Tarzan
Tim Sutton
Skype: timlinux
Jabber: timlinux
