[Qgis-developer] CMake Trunk OSX: SIP error
Martin Dobias
wonder.sk at gmail.com
Mon Feb 5 04:22:21 EST 2007
Hi Tim,
there's configure.py.in file which runs SIP utility and then creates
custom makefiles. This file is first configured by CMake to obtain the
correct paths. The way how to add GEOS would be:
1. in top part of the file create a variable with include directory
(like gdal_inc_dir):
geos_inc_dir = '@GEOS_INCLUDE_DIR@'
2. below, there are statements which specify include directories that
will be used in the makefile (search for extra_include_dirs) - just
add geos_inc_dir to that list.
Martin
On 2/5/07, Tim Sutton <tim at linfiniti.com> wrote:
> Hi Martin
> When building SIP bindings for core GEOS frameworks arent being added
> to the include path and so I think the build is failing when geos.h
> etc are not found.
> See below.
> There doesnt seem to be a CMakeList.txt in python/core - where are the
> requirements for SIP set? I looked in python/CMakeList.txt but couldnt
> work out where geos find should be added.
> Regards
> Tim
> [ 66%] Generating core/core.so
> cd /Users/tim/dev/cpp/qgis/build/python/core && /usr/bin/make
> c++ -c -DCORE_EXPORT= -pipe -fPIC -Os -Wall -W -DQT_NO_DEBUG
> -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_SQL_LIB -DQT_XML_LIB
> -I. -I/Users/tim/dev/cpp/qgis/src/core
> -I/Users/tim/dev/cpp/qgis/src/core/raster
> -I/Users/tim/dev/cpp/qgis/src/core/renderer
> -I/Users/tim/dev/cpp/qgis/src/core/spatialindex
> -I/Users/tim/dev/cpp/qgis/src/core/symbology
> -I/Users/tim/dev/cpp/qgis/build
> -I/Library/Frameworks/GDAL.framework/unix/include
> -I/System/Library/Frameworks/Python.framework/Versions/2.3/include/python2.3
> -I/usr/local/Qt4.2/mkspecs/default
> -I/Library/Frameworks/QtCore.framework/Headers
> -I/Library/Frameworks/QtGui.framework/Headers
> -I/Library/Frameworks/QtNetwork.framework/Headers
> -I/Library/Frameworks/QtSql.framework/Headers
> -I/Library/Frameworks/QtSvg.framework/Headers
> -I/Library/Frameworks/QtXml.framework/Headers
> -I/Library/Frameworks/Qt3Support.framework/Headers -I/usr/include
> -F/Users/tim/dev/cpp/qgis/build/src/core -F/Library/Frameworks -o
> sipcorecmodule.o sipcorecmodule.cpp
> In file included from /Users/tim/dev/cpp/qgis/python/core/qgsgeometry.sip:172,
> from sipcorecmodule.cpp:39:
> /Users/tim/dev/cpp/qgis/src/core/qgsgeometry.h:25:18: error: geos.h:
> No such file or directory
> /Users/tim/dev/cpp/qgis/src/core/qgsdataprovider.h:124: warning:
> unused parameter 'subset'
> /Users/tim/dev/cpp/qgis/src/core/qgsdataprovider.h:181: warning:
> unused parameter 'layers'
> /Users/tim/dev/cpp/qgis/src/core/qgsdataprovider.h:190: warning:
> unused parameter 'name'
> unused parameter 'vis'
> /Users/tim/dev/cpp/qgis/src/core/renderer/qgsrenderer.h:49: warning:
> unused parameter 'f'
> /Users/tim/dev/cpp/qgis/src/core/qgsrasterdataprovider.h:91: warning:
> unused parameter 'host'
> unused parameter 'port'
> unused parameter 'user'
> unused parameter 'pass'
> /Users/tim/dev/cpp/qgis/src/core/raster/qgsrasterlayer.h:755: warning:
> unused parameter 'other'
> /Users/tim/dev/cpp/qgis/src/core/raster/qgsrasterlayer.h:757: warning:
> /Users/tim/dev/cpp/qgis/src/core/qgscoordinatetransform.h:262:
> warning: unused parameter 'r'
> make[3]: *** [sipcorecmodule.o] Error 1
> make[2]: *** [python/core/core.so] Error 2
> make[1]: *** [python/CMakeFiles/python.dir/all] Error 2
> make: *** [all] Error 2
> tims-computer:~/dev/cpp/qgis/build tim$
> Tim Sutton
> Visit http://qgis.org for a great Open Source GIS
> Home Page: http://linfiniti.com
> Skype: timlinux
> MSN: tim_bdworld at msn.com
> Yahoo: tim_bdworld at yahoo.com
> Jabber: timlinux
> Irc: timlinux on #qgis at freenode.net
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
