[Qgis-developer] qgssvnversion.h and compile problem
Byambaa Mendbayar
mendbayar_b at mongol.net
Wed Feb 7 21:34:34 EST 2007
Dear developers,
I have a problem when I compile svn head.
D:\devel\workplace\unstable\qgis_head\build>cmake -G "MinGW Makefiles"
-DGRASS_P
REFIX=D:\devel\bin\msys\local\grass-6.3.cvs
-DCMAKE_INSTALL_PREFIX=D:\devel\work
place\unstable\qgis_head\apps D:\devel\workplace\unstable\qgis_head
-- Found Proj: D:/devel/bin/msys/local/lib/libproj.a
-- Found Sqlite3: D:/devel/bin/msys/local/lib/libsqlite3.a
-- Found GEOS: D:/devel/bin/msys/local/lib/libgeos.dll.a
-- Found GDAL: D:/devel/bin/msys/local/lib/libgdal.dll.a
-- Found PostgreSQL: D:/devel/bin/msys/local/lib/libpq.dll
-- Found Expat: D:/devel/bin/msys/local/lib/libexpat.dll.a
-- Using GSL from D:/devel/bin/msys/local
-- Found GRASS: D:/devel/bin/msys/local/grass-6.3.cvs (6.3.cvs)
-- Found Qt-Version 4.2.2
-- Configuring done
-- Generating done
-- Build files have been written to:
D:/devel/workplace/unstable/qgis_head/build
D:\devel\workplace\unstable\qgis_head\build>make
[ 0%] Built target svnversion
[ 8%] Built target ui
[ 9%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgis.obj
In file included from
D:\devel\workplace\unstable\qgis_head\src\core\qgis.cpp:4:
D:/devel/workplace/unstable/qgis_head/build/qgssvnversion.h:1: error: stray
in program
invalid to
ken
`define' d
oes not name a type
in program
missing te
rminating " character
D:/devel/workplace/unstable/qgis_head/build/qgssvnversion.h:1:49: warning:
backs
lash and newline separated by space
backs
lash-newline at end of file
D:\devel\workplace\unstable\qgis_head\src\core\qgis.cpp:13: error:
`QGSSVNVERSIO
N' was not declared in this scope
mingw32-make[2]: *** [src/core/CMakeFiles/qgis_core.dir/qgis.obj] Error 1
mingw32-make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
mingw32-make: *** [all] Error 2
After that I had lookup
D:/devel/workplace/unstable/qgis_head/build/qgssvnversion.h it was include
following line:
\ #define QGSSVNVERSION \"svn_rev_unavailable\" \
Best regards,
Byambaa Mendbayar
