[Qgis-developer] Re: qgssvnversion.h and compile problem
Magnus Homann
magnus at homann.se
Thu Feb 8 13:02:23 EST 2007
Martin Dobias wrote:
> Hi,
> I think this is due some of the recent commits which were made to fix
> compilation with 'MSYS Makefiles' generator and probably has broken
> 'MinGW Makefiles'.
> I think Tim has a definite and much better solution for showing SVN
> revision, with that fix we should be able to forget all these
> problems.
Martin is correct.
There is a README_windows.txt (since 10 secs) which mentions that you
should use sh.exe to compile, after configuring in cmd.exe.
Alternatively, run cygwin shell.
Magnus
Magnus Homann
magnus at homann.se
+46 702 399 558
