[Qgis-developer] Re: qgssvnversion.h and compile problem
Byambaa Mendbayar
mendbayar_b at mongol.net
Mon Feb 12 04:54:57 EST 2007
Dear Magnus and Martin Dobias,
Thanks a lot for your kind reply and advice. My compilation process was
successes when I use shell (sh.exe) and 'MSYS Makefiles' generator option.
Best regards,
Byambaa Mendbayar
-----Original Message-----
Sent: Friday, February 09, 2007 2:02 AM
To: Martin Dobias
Cc: mendbayar_b at mongol.net; qgis-developer
Subject: Re: [Qgis-developer] Re: qgssvnversion.h and compile problem
Martin Dobias wrote:
> Hi,
> I think this is due some of the recent commits which were made to fix
> compilation with 'MSYS Makefiles' generator and probably has broken
> 'MinGW Makefiles'.
> I think Tim has a definite and much better solution for showing SVN
> revision, with that fix we should be able to forget all these
> problems.
Martin is correct.
There is a README_windows.txt (since 10 secs) which mentions that you
should use sh.exe to compile, after configuring in cmd.exe.
Alternatively, run cygwin shell.
Magnus
Magnus Homann
magnus at homann.se
+46 702 399 558
