[Qgis-developer] Re: qgis from svn
Tim Sutton
tim at linfiniti.com
Thu Feb 15 20:50:39 EST 2007
Hi
I should also mention the spiffy new build notes I written on the wiki for osx:
http://wiki.qgis.org/qgiswiki/BuildingOnMacOsX
Maybe they will help you (and if you find any problems if you use them
let me have your corrections!).
Regards
Tim
2007/2/15, John C. Tull <jctull at gmail.com>:
> Thanks for the reply. I should have stated that I am on OS X 10.4.8.
> I am not aware that I need the SIP bindings, so I doubt I will miss
> anything. I will give it a go.
> John
> On Feb 15, 2007, at 4:54 PM, Tim Sutton wrote:
> > Hi
> > I dont have a solution for this yet, except to turn off SIP bindings.
> > If you are specificaly trying to use the python bindings that
> > obviously doesnt help. If you dont need the bindings, just do
> > rm -rf build (if you have it)
> > cmake .. (may not need to do this step)
> > ccmake ..
> > scroll right down
> > toggle the bindings option
> > press c to configure
> > press g to generate
> > press q to quit
> > If you are on the OSX system you need to edit CMakeCache.txt and
> > change gdal.so to gdal.dylib
> > If you are on linux the SIP bindings should build assuming you have
> > installed SIP and PyQt.
> > This topic is better discussed on the qgis mailing list since there
> > are people better able to help there.
> > Regards
> > Tim
> >> Tim,
> >> I am running into the problem building qgis from svn trunk regarding
> >> qgsgeometry.h that you reported as "CMake Trunk OSX: SIP error" on
> >> the qgis.devel blog system earlier this month.
> >> I was unable to work out a solution from the follow-up comment. Do
> >> you know how to get this to work without dying at:
> >> Generating core/Makefile, gui/Makefile
> >> Parsing SIP files for 'core' library...
> >> Parsing SIP files for 'gui' library...
> >> Creating makefiles...
> >> Creating qgisconfig.py...
> >> Done
> >> [ 62%] Generating core/core.so
> >> In file included from /Users/jctull/sources/qgis/python/core/
> >> qgsgeometry.sip:172,
> >> from sipcorecmodule.cpp:39:
> >> /Users/jctull/sources/qgis/src/core/qgsgeometry.h:25:18: error:
> >> geos.h: No such file or directory
> >> /Users/jctull/sources/qgis/src/core/qgsdataprovider.h:124: warning:
> >> unused parameter 'subset'
> >> /Users/jctull/sources/qgis/src/core/qgsdataprovider.h:181: warning:
> >> unused parameter 'layers'
> >> /Users/jctull/sources/qgis/src/core/qgsdataprovider.h:190: warning:
> >> unused parameter 'name'
> >> unused parameter 'vis'
> >> /Users/jctull/sources/qgis/src/core/renderer/qgsrenderer.h:49:
> >> warning: unused parameter 'f'
> >> /Users/jctull/sources/qgis/src/core/qgsrasterdataprovider.h:91:
> >> warning: unused parameter 'host'
> >> warning: unused parameter 'port'
> >> warning: unused parameter 'user'
> >> warning: unused parameter 'pass'
> >> /Users/jctull/sources/qgis/src/core/raster/qgsrasterlayer.h:755:
> >> warning: unused parameter 'other'
> >> /Users/jctull/sources/qgis/src/core/raster/qgsrasterlayer.h:757:
> >> /Users/jctull/sources/qgis/src/core/qgscoordinatetransform.h:262:
> >> warning: unused parameter 'r'
> >> gmake[3]: *** [sipcorecmodule.o] Error 1
> >> make[2]: *** [python/core/core.so] Error 2
> >> make[1]: *** [python/CMakeFiles/python.dir/all] Error 2
> >> make: *** [all] Error 2
> >> Thanks,
> >> John
> >> John C. Tull, Ph.D.
> >> Post-doctoral Scholar
> >> MS-315 Department of Biology
> >> University of Nevada
> >> Reno, NV 89557
> >> 775-784-4804
> >> FAX 775-784-1369
> > Tim Sutton
> > Visit http://qgis.org for a great Open Source GIS
> > Home Page: http://linfiniti.com
> > Skype: timlinux
> > MSN: tim_bdworld at msn.com
> > Yahoo: tim_bdworld at yahoo.com
> > Jabber: timlinux
> > Irc: timlinux on #qgis at freenode.net
Tim Sutton
Skype: timlinux
Jabber: timlinux
