[Qgis-developer] Re: qgis from svn
Tim Sutton tim at linfiniti.com
Fri Feb 16 07:38:16 EST 2007
Hi
2007/2/16, John C. Tull <jctull at gmail.com>:
> Again, I was not very informative in my original email. Seriously, I
> am not usually such a poor communicator.
No worries I was half asleep when I responded to your emails too, so
it could just have been me not reading your messages carefully enough.
The wiki is where I started
> and got stuck. It might be work including information about dealing
> with this SIP problem that seems to have arisen since you originally
> added the new build instructions.
Good idea I'll try to do that on the weekend...of course its a wiki so
if you create yourself account and let me know your UserName I can
give you write access and you can just tweak the notes directly with
your additional thoughts & observations (they would be greatly
appreciated).
> I also changed all the libgdal.so instances and libpq.so instances to
> *.dylib. I did not know if that was necessary, but it did build fine.
Yes its stil neccessary if you are building using Williams frameworks.
> I would also suggest a brief mention of how to update your subversion
> directory using the 'svn update' command from the root qgis folder.
I could do or perhps just link off to another page on using svn (I
suspect we already have this documnented somewhere - we certainly have
some svn centric pages).
> There will be people unsure about that, although these may not be the
> people trying to build the bleeding edge stuff.
> Again, thanks for your help. Your blog tutorials are a nice resource.
> Please keep them coming!
Thanks - I need to go through all the existing ones and check they
still work with the changes in api in trunk. But I have many more
planned if I can just find the time....
I look forward to monitoring and taking
> advantage of the progress on Qgis.
Good. One last comment is that it would be better (for both of us) if
you communicate via the developer and or users mailing lists as:
1) if you have questions I can answer others may be able to
2) I dont have to answer the same questions many times when they are
asked and answered in a public forum
3) My time is limited and dont always have the ability to answer
individual queries
Best regards and happy QGISSing
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
