[Qgis-developer] Merge of refactoring branch
Martin Dobias
wonder.sk at gmail.com
Mon Jan 8 04:22:03 EST 2007
Hi Paolo,
it's briefly described on wiki (section Building with CMake):
http://wiki.qgis.org/qgiswiki/Splitting_Into_Libraries
you can use 'ccmake' program for tweaking the parameter or you can use
something like:
cmake -DVARIABLE1=value1 -DVARIABLE2=value2
to specify the parameters from command line.
Martin
On 1/8/07, Paolo Cavallini <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all.
> Sorry for my ignorance: how do I choose the install options with Cmake?
> I normally use:
> ./autogen.sh --with-qtdir=/usr/share/qt4
> - --with-grass=/usr/local/grass-6.2.1 --with-python --with-wfs
> All the best.
> pc
> Martin Dobias ha scritto:
> > = Build system =
> > To build it, you will need CMake (version 2.4 or preferably later). It
> > has been tested and builds and runs well under Linux and Windows. I
> > have no access to Mac, so I couldn't test there. I'm all for using
> > CMake as the only make system as it's universal, flexible and easy to
> > understand.
> > Thus I also suggest removing autotools and qmake files as they are not
> > needed anymore and might confuse people. As not much people know CMake
> > so far, we could make a wrapper 'configure' script that will help
> > users with the transition.
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFFognr/NedwLUzIr4RAiJ+AJ9xaiobU7OqRseLQaWoDOgKOKKeWACgqv53
> vfv4ijdBhuII+JOgSs6rm/E=
> =Y8B+
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
