[Qgis-developer] Merge of refactoring branch
Paolo Cavallini
cavallini at faunalia.it
Tue Jan 9 03:40:34 EST 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
Trying to build and got the first problems:
cmake .. -DGRASS_PREFIX=/usr/local/grass-6.2.1
- -- Could not find GRASS
With ccmake I can specify the GRASS_PREFIX, but then:
# make
[ 0%] Built target svnversion
[ 9%] Built target ui
[ 9%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgis.o
/home/paolo/Desktop/buildpackage/qgis/src/core/qgis.cpp:10: error:
‘VERSION’ was not declared in this scope
make[2]: *** [src/core/CMakeFiles/qgis_core.dir/qgis.o] Error 1
BISON_EXECUTABLE /usr/bin/bison
CMAKE_BACKWARDS_COMPATIBILITY 2.4
CMAKE_BUILD_TYPE
CMAKE_INSTALL_PREFIX /usr/local
EXECUTABLE_OUTPUT_PATH
EXPAT_INCLUDE_DIR /usr/include
EXPAT_LIBRARY /usr/lib/libexpat.so
FLEX_EXECUTABLE /usr/bin/flex
GDAL_CONFIG /usr/bin/gdal-config
GDAL_CONFIG_PREFER_PATH /bin
GDAL_INCLUDE_DIR
/build/buildd/gdal-1.3.2/debian/tmp/usr/include
GDAL_LIBRARY
/build/buildd/gdal-1.3.2/debian/tmp/usr/lib/libgdal1.3.2.so
GEOS_INCLUDE_DIR /usr/include
GEOS_LIBRARY /usr/lib/libgeos.so
GRASS_INCLUDE_DIR
GRASS_PREFIX /usr/local/grass-6.2.1
GSL_CONFIG /usr/bin/gsl-config
GSL_CONFIG_PREFER_PATH /bin
GSL_EXE_LINKER_FLAGS -Wl,-rpath,/usr/lib
LIBRARY_OUTPUT_PATH
LIB_PATH
/usr/local/grass-6.2.1/lib/libgrass_gproj.so
POSTGRES_CONFIG /usr/bin/pg_config
POSTGRES_CONFIG_PREFER_PATH /bin
POSTGRES_INCLUDE_DIR /usr/include/postgresql
POSTGRES_LIBRARY /usr/lib/libpq.so
PROJ_INCLUDE_DIR /usr/include
PROJ_LIBRARY /usr/lib/libproj.so
PYTHON_EXECUTABLE /usr/bin/python2.4
PYTHON_INCLUDE_PATH /usr/include/python2.4
PYTHON_LIBRARY /usr/lib/python2.4/config/libpython2.4.so
QGIS_NO_SVNVERSION OFF
QT_LRELEASE_EXECUTABLE /usr/bin/lrelease
QT_MKSPECS_DIR /usr/share/qt4/mkspecs
QT_PLUGINS_DIR /usr/lib/qt4/plugins
QT_QMAKE_EXECUTABLE /usr/bin/qmake-qt4
QT_X11_X11_LIBRARY /usr/lib/libX11.so
QT_X11_Xext_LIBRARY /usr/lib/libXext.so
QT_X11_m_LIBRARY /usr/lib/libm.so
SIP_BINARY_PATH /usr/bin/sip
SQLITE3_INCLUDE_DIR /usr/include
SQLITE3_LIBRARY /usr/lib/libsqlite3.so
Any hint?
All the best.
pc
Martin Dobias ha scritto:
> Hi Paolo,
> it's briefly described on wiki (section Building with CMake):
> http://wiki.qgis.org/qgiswiki/Splitting_Into_Libraries
> you can use 'ccmake' program for tweaking the parameter or you can use
> something like:
> cmake -DVARIABLE1=value1 -DVARIABLE2=value2
> to specify the parameters from command line.
> Martin
> On 1/8/07, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Hi all.
> Sorry for my ignorance: how do I choose the install options with Cmake?
> I normally use:
> ./autogen.sh --with-qtdir=/usr/share/qt4
> --with-grass=/usr/local/grass-6.2.1 --with-python --with-wfs
> All the best.
> pc
Paolo Cavallini
email+jabber: cavallini at faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFFo1UC/NedwLUzIr4RAnr3AKC0KOTXiJ90Jwgv5Rog0JnYJtaD0QCfSTPP
BnfcmEytBXiWH1AdrH1d4D8=
=A9vW
-----END PGP SIGNATURE-----
