[Qgis-developer] Improved GRASS check
Martin Dobias
wonder.sk at gmail.com
Tue Jan 9 18:41:57 EST 2007
in revision 6419 I've refined a bit the check for GRASS. How does it work now:
- you can specify WITH_GRASS variable - ON or OFF - it's on by default
so you can use it to disable GRASS support explicitly
- you can specify GRASS path using GRASS_PREFIX variable. Besides this
it supports some default paths - for now it's just (K)ubuntu's
/usr/lib/grass ... if you give me a note what directory your distro
uses by default I can add it so it will detected automatically
- check for GRASS now displays the version that has been detected (by
reading grass-prefix/etc/VERSIONNUMBER)
Martin
