[Qgis-developer] Mac CMake Status
Tom Elwertowski
telwertowski at comcast.net
Thu Jan 11 18:37:47 EST 2007
Hi all
QGIS/Mac will now run from the command line when built by CMake if
DYLD_LIBRARY_PATH contains the path to the qgis libraries
(install-prefix/qgis.app/Contents/MacOS/lib).
It is not double-clickable yet because the library paths are not
contained in the libraries and plugins (hence the need for
DYLD_LIBRARY_PATH).
When running cmake, some dependencies may be found and recorded as .so.
Change these to .dylib which is the correct Mac library extension before
running make.
Tom
