[Qgis-developer] Mac CMake Status
Tim Sutton
tim at linfiniti.com
Thu Jan 11 22:01:35 EST 2007
Hi Tom
Ive been trying to build on mac but its tripping up with:
[ 0%] Built target svnversion
[ 10%] Built target ui
make[2]: *** No rule to make target `/usr/local/lib/libgdal.so',
needed by `src/core/libqgis_core.dylib'. Stop.
make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
make: *** [all] Error 2
Any ideas? I was also wondering how to get it to use the gdal from
Williams frameworks rather than the one I have installed in
/usr/local/lib
Regards
Tim
On 1/11/07, Tom Elwertowski <telwertowski at comcast.net> wrote:
> Hi all
> QGIS/Mac will now run from the command line when built by CMake if
> DYLD_LIBRARY_PATH contains the path to the qgis libraries
> (install-prefix/qgis.app/Contents/MacOS/lib).
> It is not double-clickable yet because the library paths are not
> contained in the libraries and plugins (hence the need for
> DYLD_LIBRARY_PATH).
> When running cmake, some dependencies may be found and recorded as .so.
> Change these to .dylib which is the correct Mac library extension before
> running make.
> Tom
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
