[Qgis-developer] CMake on Windows
Byambaa Mendbayar
mendbayar_b at mongol.net
Mon Jan 15 05:05:57 EST 2007
Dear Tim and developers
In first of all thanks a lot for your reply on SVN 6410 compile problem. I
was compiling it using your suggested method.
In today I have trying to compile latest QGIS SVN build using CMAKE
(CMake-2.4.6 for Windows). However I didn't get success. I have got
following error messages:
1. cmake c:\dev\cpp\qgis.latest
C:\dev\cpp\qgis.latest>cmake c:\dev\cpp\qgis.latest
CMake Error: CMake was unable to find a build program corresponding to
"Visual S
tudio 6". CMAKE_MAKE_PROGRAM is not set. You probably need to select a
differe
nt build tool.
CMake Error: Could not find cmake module
file:c:/dev/cpp/qgis.latest/CMakeFiles/
CMakeCCompiler.cmake
CMakeCXXCompiler.cmake
-- Configuring done
2. cmake -G MinGW Makefiles c:\dev\cpp\qgis.latest
C:\dev\cpp\qgis.latest>cmake -G MinGW Makefiles c:\dev\cpp\qgis.latest
CMake Error: Could not create named generator MinGW
I have using your suggested compilation environment. (msys.tar.gz,
MinGW-5.1.2.exe, qt-win-opensource-4.2.2-mingw.exe + latest QGIS SVN 6434
source)
After that I was using cmakeSetup.exe, it was generating following:
Error
CMake Error: This project requires some variables to be set,
and cmake can not find them.
Please set the following variables:
GDAL_INCLUDE_DIR
GEOS_INCLUDE_DIR
PROJ_INCLUDE_DIR
SQLITE3_INCLUDE_DIR
(Press Cancel to suppress any further messages.)
OK Cancel
What I will do, what am I wrong? Please help me.
Thanks and best regards,
Byambaa Mendbayar
