[Qgis-user][Qgis-developer] measuring tool
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Thu Jan 18 02:28:45 EST 2007
Am Mittwoch, 17. Januar 2007 20:19 schrieb Magnus Homann:
> The projection used to determine scale/measurement will be project
> projection (if turned on) or active layer(???) if off.
I'm using QGIS quite often without projection turned on. In this case, the
result I would expect is just a simple 2D measurement and the units are taken
from the project properties.
cheers,
Marco
