[Qgis-developer] CMake on Windows
Byambaa Mendbayar
mendbayar_b at mongol.net
Fri Jan 19 00:20:53 EST 2007
Dear Martin,
Thanks a lot for you nice reply.
I have trying to compile latest qgis source on windows.
I was using cmakeSetup.exe and manually configure missed things, please see
following:
C:\dev\cpp\qgis.latest>cmake -G "MinGW Makefiles" c:\dev\cpp\qgis.latest
-- Found Proj: c:/msys/local/lib/libproj.a
-- Found Sqlite3: c:/msys/local/lib/libsqlite3.a
-- Found GEOS: c:/msys/local/lib/libgeos.dll.a
-- Found GDAL: c:/msys/local/lib/libgdal.dll.a
-- Found PostgreSQL: c:/msys/local/lib/libpq.dll
-- Found Expat: c:/msys/local/lib/libexpat.dll.a
-- Using GSL from
-- Found Qt-Version 4.2.2
-- Configuring done
-- Generating done
-- Build files have been written to: c:/dev/cpp/qgis.latest
After that I was compile it using make command then getting some error
messages.
c:\dev\cpp\qgis.latest\src\core\qgscoordinatetransform.cpp: In member
function `
void QgsCoordinateTransform::setFinder()':
c:\dev\cpp\qgis.latest\src\core\qgscoordinatetransform.cpp:579: error:
`pj_set_finder' undeclared (first use this function)
mingw32-make[2]: ***
[src/core/CMakeFiles/qgis_core.dir/qgscoordinatetransform.o
bj] Error 1
mingw32-make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
mingw32-make: *** [all] Error 2
What's wrong in my case?
Best regards,
Byambaa Mendbayar
-----Original Message-----
From: Martin Dobias [mailto:wonder.sk at gmail.com]
Sent: Monday, January 15, 2007 6:20 PM
To: mendbayar_b at mongol.net
Cc: Tim Sutton; QGIS-dev
Subject: Re: [Qgis-developer] CMake on Windows
as you can see, the default generator for Windows is generator for
visual studio. Thus you need to say explicitly:
(notice the double quotes to parse it as one argument.
On windows there's nothing like default path for libraries and include
directories - that's the reason why you have to set the paths
explicitly for the dependencies. (However in future we can decide that
c:\msys is our default path for windows build and it will detect
everything automatically as it does on unix.
Good luck,
Martin
On 1/15/07, Byambaa Mendbayar <mendbayar_b at mongol.net> wrote:
> Dear Tim and developers
> In first of all thanks a lot for your reply on SVN 6410 compile problem. I
> was compiling it using your suggested method.
> In today I have trying to compile latest QGIS SVN build using CMAKE
> (CMake-2.4.6 for Windows). However I didn't get success. I have got
> following error messages:
> 1. cmake c:\dev\cpp\qgis.latest
> C:\dev\cpp\qgis.latest>cmake c:\dev\cpp\qgis.latest
> CMake Error: CMake was unable to find a build program corresponding to
> "Visual S
> tudio 6". CMAKE_MAKE_PROGRAM is not set. You probably need to select a
> differe
> nt build tool.
> CMake Error: Could not find cmake module
> file:c:/dev/cpp/qgis.latest/CMakeFiles/
> CMakeCCompiler.cmake
> CMakeCXXCompiler.cmake
> -- Configuring done
> 2. cmake -G MinGW Makefiles c:\dev\cpp\qgis.latest
> C:\dev\cpp\qgis.latest>cmake -G MinGW Makefiles c:\dev\cpp\qgis.latest
> CMake Error: Could not create named generator MinGW
> I have using your suggested compilation environment. (msys.tar.gz,
> MinGW-5.1.2.exe, qt-win-opensource-4.2.2-mingw.exe + latest QGIS SVN 6434
> source)
> After that I was using cmakeSetup.exe, it was generating following:
> Error
> CMake Error: This project requires some variables to be set,
> and cmake can not find them.
> Please set the following variables:
> GDAL_INCLUDE_DIR
> GEOS_INCLUDE_DIR
> PROJ_INCLUDE_DIR
> SQLITE3_INCLUDE_DIR
> (Press Cancel to suppress any further messages.)
> OK Cancel
> What I will do, what am I wrong? Please help me.
> Thanks and best regards,
> Byambaa Mendbayar
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
