[Qgis-developer] CMake on Windows
Byambaa Mendbayar
mendbayar_b at mongol.net
Fri Jan 19 04:51:18 EST 2007
Dear Tim and Martin,
Excuse me for my raw mistake. It was include path problem, now every thing
works fine, now compilation process is OK.
Thank you very much.
Another thing
The vector layer editing functionality is not work correctly when I use my
own compiled QGIS. I have trying to edit existing SHP vector file also
creating new vector layer using QGIS. These are either is not work, it was
alerting me please check allow editing etc... Of course I have already
chosen (tick) start editing on my active (working) vector layer.
With kind regards,
Byambaa Mendbayar
-----Original Message-----
Sent: Friday, January 19, 2007 4:50 PM
To: mendbayar_b at mongol.net
Subject: Re: [Qgis-developer] CMake on Windows
Hi
It looks like its missing proj4 headers in the msys bundle. What is
the include path that is being used?
Regards
Tim
On 1/19/07, Byambaa Mendbayar <mendbayar_b at mongol.net> wrote:
> Dear Martin,
> Thanks a lot for you nice reply.
> I have trying to compile latest qgis source on windows.
> I was using cmakeSetup.exe and manually configure missed things, please
see
> following:
> C:\dev\cpp\qgis.latest>cmake -G "MinGW Makefiles" c:\dev\cpp\qgis.latest
> -- Found Proj: c:/msys/local/lib/libproj.a
> -- Found Sqlite3: c:/msys/local/lib/libsqlite3.a
> -- Found GEOS: c:/msys/local/lib/libgeos.dll.a
> -- Found GDAL: c:/msys/local/lib/libgdal.dll.a
> -- Found PostgreSQL: c:/msys/local/lib/libpq.dll
> -- Found Expat: c:/msys/local/lib/libexpat.dll.a
> -- Using GSL from
> -- Found Qt-Version 4.2.2
> -- Configuring done
> -- Generating done
> -- Build files have been written to: c:/dev/cpp/qgis.latest
> After that I was compile it using make command then getting some error
> messages.
> c:\dev\cpp\qgis.latest\src\core\qgscoordinatetransform.cpp: In member
> function `
> void QgsCoordinateTransform::setFinder()':
> c:\dev\cpp\qgis.latest\src\core\qgscoordinatetransform.cpp:579: error:
> `pj_set_finder' undeclared (first use this function)
> mingw32-make[2]: ***
> [src/core/CMakeFiles/qgis_core.dir/qgscoordinatetransform.o
> bj] Error 1
> mingw32-make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
> mingw32-make: *** [all] Error 2
> What's wrong in my case?
> Best regards,
> Byambaa Mendbayar
> From: Martin Dobias [mailto:wonder.sk at gmail.com]
> Sent: Monday, January 15, 2007 6:20 PM
> Cc: Tim Sutton; QGIS-dev
> Hi,
> as you can see, the default generator for Windows is generator for
> visual studio. Thus you need to say explicitly:
> (notice the double quotes to parse it as one argument.
> On windows there's nothing like default path for libraries and include
> directories - that's the reason why you have to set the paths
> explicitly for the dependencies. (However in future we can decide that
> c:\msys is our default path for windows build and it will detect
> everything automatically as it does on unix.
> Good luck,
> Martin
> On 1/15/07, Byambaa Mendbayar <mendbayar_b at mongol.net> wrote:
> > Dear Tim and developers
> > In first of all thanks a lot for your reply on SVN 6410 compile problem.
I
> > was compiling it using your suggested method.
> > In today I have trying to compile latest QGIS SVN build using CMAKE
> > (CMake-2.4.6 for Windows). However I didn't get success. I have got
> > following error messages:
> > 1. cmake c:\dev\cpp\qgis.latest
> > C:\dev\cpp\qgis.latest>cmake c:\dev\cpp\qgis.latest
> > CMake Error: CMake was unable to find a build program corresponding to
> > "Visual S
> > tudio 6". CMAKE_MAKE_PROGRAM is not set. You probably need to select a
> > differe
> > nt build tool.
> > CMake Error: Could not find cmake module
> > file:c:/dev/cpp/qgis.latest/CMakeFiles/
> > CMakeCCompiler.cmake
> > CMakeCXXCompiler.cmake
> > -- Configuring done
> > 2. cmake -G MinGW Makefiles c:\dev\cpp\qgis.latest
> > C:\dev\cpp\qgis.latest>cmake -G MinGW Makefiles c:\dev\cpp\qgis.latest
> > CMake Error: Could not create named generator MinGW
> > I have using your suggested compilation environment. (msys.tar.gz,
> > MinGW-5.1.2.exe, qt-win-opensource-4.2.2-mingw.exe + latest QGIS SVN
6434
> > source)
> > After that I was using cmakeSetup.exe, it was generating following:
> > Error
> > CMake Error: This project requires some variables to be set,
> > and cmake can not find them.
> > Please set the following variables:
> > GDAL_INCLUDE_DIR
> > GEOS_INCLUDE_DIR
> > PROJ_INCLUDE_DIR
> > SQLITE3_INCLUDE_DIR
> > (Press Cancel to suppress any further messages.)
> > OK Cancel
> > What I will do, what am I wrong? Please help me.
> > Thanks and best regards,
> > Byambaa Mendbayar
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
