[Qgis-developer] CMake on Windows
Martin Dobias
wonder.sk at gmail.com
Fri Jan 19 05:13:23 EST 2007
On 1/19/07, Byambaa Mendbayar <mendbayar_b at mongol.net> wrote:
> Dear Tim and Martin,
> Excuse me for my raw mistake. It was include path problem, now every thing
> works fine, now compilation process is OK.
> Thank you very much.
Glad to hear it's working now!
> Another thing
> The vector layer editing functionality is not work correctly when I use my
> own compiled QGIS. I have trying to edit existing SHP vector file also
> creating new vector layer using QGIS. These are either is not work, it was
> alerting me please check allow editing etc... Of course I have already
> chosen (tick) start editing on my active (working) vector layer.
I know that some commands stopped working - until it will be fixed,
here's a temporary solution: right click on legend, toggle show file
groups on. open the 'Files' item under the layer you want to edit and
right click the file name. You should get a similar popup menu, but
this one should be working (also displaying attribute table works from
there).
Martin
> With kind regards,
> Byambaa Mendbayar
> -----Original Message-----
> From: Tim Sutton [mailto:tim at linfiniti.com]
> Sent: Friday, January 19, 2007 4:50 PM
> To: mendbayar_b at mongol.net
> Subject: Re: [Qgis-developer] CMake on Windows
> Hi
> It looks like its missing proj4 headers in the msys bundle. What is
> the include path that is being used?
> Regards
> Tim
> > Dear Martin,
> > Thanks a lot for you nice reply.
> > I have trying to compile latest qgis source on windows.
> > I was using cmakeSetup.exe and manually configure missed things, please
> see
> > following:
> > C:\dev\cpp\qgis.latest>cmake -G "MinGW Makefiles" c:\dev\cpp\qgis.latest
> > -- Found Proj: c:/msys/local/lib/libproj.a
> > -- Found Sqlite3: c:/msys/local/lib/libsqlite3.a
> > -- Found GEOS: c:/msys/local/lib/libgeos.dll.a
> > -- Found GDAL: c:/msys/local/lib/libgdal.dll.a
> > -- Found PostgreSQL: c:/msys/local/lib/libpq.dll
> > -- Found Expat: c:/msys/local/lib/libexpat.dll.a
> > -- Using GSL from
> > -- Found Qt-Version 4.2.2
> > -- Configuring done
> > -- Generating done
> > -- Build files have been written to: c:/dev/cpp/qgis.latest
> > After that I was compile it using make command then getting some error
> > messages.
> > c:\dev\cpp\qgis.latest\src\core\qgscoordinatetransform.cpp: In member
> > function `
> > void QgsCoordinateTransform::setFinder()':
> > c:\dev\cpp\qgis.latest\src\core\qgscoordinatetransform.cpp:579: error:
> > `pj_set_finder' undeclared (first use this function)
> > mingw32-make[2]: ***
> > [src/core/CMakeFiles/qgis_core.dir/qgscoordinatetransform.o
> > bj] Error 1
> > mingw32-make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
> > mingw32-make: *** [all] Error 2
> > What's wrong in my case?
> > Best regards,
> > Byambaa Mendbayar
> > From: Martin Dobias [mailto:wonder.sk at gmail.com]
> > Sent: Monday, January 15, 2007 6:20 PM
> > Cc: Tim Sutton; QGIS-dev
> > Hi,
> > as you can see, the default generator for Windows is generator for
> > visual studio. Thus you need to say explicitly:
> > (notice the double quotes to parse it as one argument.
> > On windows there's nothing like default path for libraries and include
> > directories - that's the reason why you have to set the paths
> > explicitly for the dependencies. (However in future we can decide that
> > c:\msys is our default path for windows build and it will detect
> > everything automatically as it does on unix.
> > Good luck,
> > Martin
> > On 1/15/07, Byambaa Mendbayar <mendbayar_b at mongol.net> wrote:
> > > Dear Tim and developers
> > > In first of all thanks a lot for your reply on SVN 6410 compile problem.
> I
> > > was compiling it using your suggested method.
> > > In today I have trying to compile latest QGIS SVN build using CMAKE
> > > (CMake-2.4.6 for Windows). However I didn't get success. I have got
> > > following error messages:
> > > 1. cmake c:\dev\cpp\qgis.latest
> > > C:\dev\cpp\qgis.latest>cmake c:\dev\cpp\qgis.latest
> > > CMake Error: CMake was unable to find a build program corresponding to
> > > "Visual S
> > > tudio 6". CMAKE_MAKE_PROGRAM is not set. You probably need to select a
> > > differe
> > > nt build tool.
> > > CMake Error: Could not find cmake module
> > > file:c:/dev/cpp/qgis.latest/CMakeFiles/
> > > CMakeCCompiler.cmake
> > > CMakeCXXCompiler.cmake
> > > -- Configuring done
> > > 2. cmake -G MinGW Makefiles c:\dev\cpp\qgis.latest
> > > C:\dev\cpp\qgis.latest>cmake -G MinGW Makefiles c:\dev\cpp\qgis.latest
> > > CMake Error: Could not create named generator MinGW
> > > I have using your suggested compilation environment. (msys.tar.gz,
> > > MinGW-5.1.2.exe, qt-win-opensource-4.2.2-mingw.exe + latest QGIS SVN
> 6434
> > > source)
> > > After that I was using cmakeSetup.exe, it was generating following:
> > > Error
> > > CMake Error: This project requires some variables to be set,
> > > and cmake can not find them.
> > > Please set the following variables:
> > > GDAL_INCLUDE_DIR
> > > GEOS_INCLUDE_DIR
> > > PROJ_INCLUDE_DIR
> > > SQLITE3_INCLUDE_DIR
> > > (Press Cancel to suppress any further messages.)
> > > OK Cancel
> > > What I will do, what am I wrong? Please help me.
> > > Thanks and best regards,
> > > Byambaa Mendbayar
> > > _______________________________________________
> > > Qgis-developer mailing list
> > > Qgis-developer at lists.qgis.org
> > > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> Tim Sutton
> Visit http://qgis.org for a great Open Source GIS
> Home Page: http://linfiniti.com
> Skype: timlinux
> MSN: tim_bdworld at msn.com
> Yahoo: tim_bdworld at yahoo.com
> Jabber: timlinux
> Irc: timlinux on #qgis at freenode.net
