[Qgis-developer] HOW TO COMPILE QGIS FROM SOURCE CODE FOR WINDOWS?
Martin Dobias
wonder.sk at gmail.com
Mon Jan 22 05:10:36 EST 2007
instructions for compiling 0.8 version are in readme_windows.txt file
in sources. However I would recommend you to download QGIS with
installer (unless you're going to do some development) as it's not
straightforward to compile it on windows.
plugin_builder.pl is just a simple script that creates sources for a
new plugin from template - no reason to use it unless you're
developing a new plugin.
Martin
> For adding extra plugins to qgis after installing in windows...require to
> run perl script in /../src/plugins/plugin_builder.pl.?
> right?
> but after installation,there is no such folder(src)in the installed qgis
> folder,.......solution?????
> cn i copy the src folder from qgis source code to qgis installed
> folder??????? and execute perl script....any probs????
> jaan
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
