[Qgis-developer] HOW TO COMPILE QGIS FROM SOURCE CODE FOR WINDOWS?
Byambaa Mendbayar
mendbayar_b at mongol.net
Tue Jan 23 23:11:54 EST 2007
Hi Magnus,
Yep, I did it. In my case I have using cmake 2.4.6 within MinGW-5.1.2 and
bundled MSYS (http://qgis.org/uploadfiles/msys/msys.tar.gz) provided by Tim
Sutton.
By the way default configuration of CMakeLists.txt isn't define some
depended libraries paths (lib and include), therefore you should assign it
using cmakesetup tool or manually edit CMakeLists.txt. In personally I
suggest to you using cmakeSetup.exe tool for configuring QGIS.
Best regards,
Byambaa Mendbayar
-----Original Message-----
[mailto:qgis-developer-bounces at lists.qgis.org] On Behalf Of Magnus Homann
Sent: Wednesday, January 24, 2007 3:08 AM
To: qgis-developer at lists.qgis.org
Subject: Re: [Qgis-developer] HOW TO COMPILE QGIS FROM SOURCE CODE FOR
WINDOWS?
Good question! Has anyone succeeded to compile Windows wtih cmake?
I get compile errors in src/core/spatialindex
Magnus
Magnus Homann
magnus at homann.se
+46 702 399 558
Qgis-developer mailing list
Qgis-developer at lists.qgis.org
http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
