[Qgis-developer] HOW TO COMPILE QGIS FROM SOURCE CODE FOR WINDOWS?
Martin Dobias wonder.sk at gmail.com
Wed Jan 24 04:18:34 EST 2007
On 1/24/07, Byambaa Mendbayar <mendbayar_b at mongol.net> wrote:
> By the way default configuration of CMakeLists.txt isn't define some
> depended libraries paths (lib and include), therefore you should assign it
> using cmakesetup tool or manually edit CMakeLists.txt. In personally I
> suggest to you using cmakeSetup.exe tool for configuring QGIS.
Just a small note: yesterday I've added c:\msys\local\include and
c:\msys\local\lib to default search path for dependencies, so if you
have it in this path, it should configure automatically without the
need for manual settings.
Martin
