[Qgis-developer] Problems building in Windows using cmake
godofredo contreras
frdcn at hotmail.com
Fri Jan 26 17:04:43 EST 2007
This is weird, I´m using SVN trunk 6459.It does not detect the variables automatically also I set the variables in the form that you suggested and it still does not work.
I tried running cmake from cmd, qt console and msys with the same results. I will give a try to cmakesetup.
Regards
Godofredo Contreras
> Date: Fri, 26 Jan 2007 22:32:01 +0100> From: wonder.sk at gmail.com> To: frdcn at hotmail.com> Subject: Re: [Qgis-developer] Problems building in Windows using cmake> CC: qgis-developer at lists.qgis.org> > Hi,> > if you're using latest SVN trunk (at least 6453), the libraries should> be found automatically if you have msys environment in c:\msys.> > There is always possibility to specify the missing variables> (*_LIBRARY and *_INCLUDE_DIR) in a configuration program called> CMakeSetup (graphical tool similar to ccmake on unixes).> > Specifying the library doesn't help? Do your settings for the deps> look like this:> GDAL_INCLUDE_DIR = c:/msys/local/include> GDAL_LIBRARY = c:/msys/local/lib/libgdal.dll.a> > > Martin> > > On 1/26/07, godofredo contreras <frdcn at hotmail.com> wrote:> >> > Hi:> >> > I've been trying to build qgis using cmake in windows but I'm getting this:> >> > C:\msys\bin>cmake -G "MinGW Makefiles" c:/dev/cpp/qgis.latest> > -- Could not find PostgreSQL> > -- Could not find Expat> > -- Could not find GRASS> > CMake Error: Some dependencies were not found!> > -- Found Qt-Version 4.2.2> > CMake Error: This project requires some variables to be set,> > and cmake can not find them.> > Please set the following variables:> > GDAL_LIBRARY> > GEOS_LIBRARY> > PROJ_LIBRARY> > SQLITE3_LIBRARY> > -- Configuring done> >> > I got the latest source code from svn and the latest msys. Also I tried> > setting the variables suggested with no success.> >> >> > Regards Godofredo Contreras> >> > ________________________________> > Get live scores and news about your team: Add the Live.com Football Page> > Check it out!> > _______________________________________________> > Qgis-developer mailing list> > Qgis-developer at lists.qgis.org> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer> >> >> >
_________________________________________________________________
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy!
http://clk.atdmt.com/MSN/go/msnnkwsp0070000001msn/direct/01/?href=http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20070126/32b4f485/attachment.html
