[Qgis-developer] Problems building in Windows using cmake
Martin Dobias
wonder.sk at gmail.com
Fri Jan 26 16:32:01 EST 2007
if you're using latest SVN trunk (at least 6453), the libraries should
be found automatically if you have msys environment in c:\msys.
There is always possibility to specify the missing variables
(*_LIBRARY and *_INCLUDE_DIR) in a configuration program called
CMakeSetup (graphical tool similar to ccmake on unixes).
Specifying the library doesn't help? Do your settings for the deps
look like this:
GDAL_INCLUDE_DIR = c:/msys/local/include
GDAL_LIBRARY = c:/msys/local/lib/libgdal.dll.a
Martin
On 1/26/07, godofredo contreras <frdcn at hotmail.com> wrote:
> Hi:
> I've been trying to build qgis using cmake in windows but I'm getting this:
> C:\msys\bin>cmake -G "MinGW Makefiles" c:/dev/cpp/qgis.latest
> -- Could not find PostgreSQL
> -- Could not find Expat
> -- Could not find GRASS
> CMake Error: Some dependencies were not found!
> -- Found Qt-Version 4.2.2
> CMake Error: This project requires some variables to be set,
> and cmake can not find them.
> Please set the following variables:
> GDAL_LIBRARY
> GEOS_LIBRARY
> PROJ_LIBRARY
> SQLITE3_LIBRARY
> -- Configuring done
> I got the latest source code from svn and the latest msys. Also I tried
> setting the variables suggested with no success.
> Regards Godofredo Contreras
> ________________________________
> Get live scores and news about your team: Add the Live.com Football Page
> Check it out!
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
