[Qgis-developer] TRUNK SIP related OSX build fail
Tim Sutton
tim at linfiniti.com
Fri Mar 2 06:32:28 EST 2007
Hi
Thanks for the info and fix guys I still get the error shown below
after Martins update. Ill poke around with it on the weekend a bit
more to try to get it fixed. Martin - yeah it would be great to get
rid of any final vestages of Qt3 in the code base.
Regards
Tim
/Users/tim/dev/cpp/qgis/src/core/qgscoordinatetransform.h:262:
warning: unused parameter 'r'
/usr/bin/ld: warning can't open dynamic library:
Qt3Support.framework/Versions/4/Qt3Support referenced from:
/Users/tim/dev/cpp/qgis/build/src/core/libqgis_core.dylib (checking
for undefined symbols may be affected) (No such file or directory,
errno = 2)
/usr/bin/ld: Undefined symbols:
Q3PtrCollection::newItem(void*) referenced from libqgis expected to
be defined in Qt3Support.framework/Versions/4/Qt3Support
Q3GDict::look_string(QString const&, void*, int)referenced from
libqgis expected to be defined in
Q3GDict::remove_string(QString const&, void*)referenced from libqgis
expected to be defined in Qt3Support.framework/Versions/4/Qt3Support
Q3GDict::read(QDataStream&, void*&) referenced from libqgis expected
Q3GDict::clear() referenced from libqgis expected to be defined in
Q3GDict::~Q3GDict()referenced from libqgis expected to be defined in
Q3GDict::write(QDataStream&, void*) constreferenced from libqgis
typeinfo for Q3GDictreferenced from libqgis expected to be defined in
Q3GDictIterator::Q3GDictIterator(Q3GDict const&)referenced from
Q3GDictIterator::~Q3GDictIterator()referenced from libqgis expected to
Q3GDictIterator::operator++()referenced from libqgis expected to be
Q3GDict::Q3GDict(unsigned int, Q3GDict::KeyType, bool, bool)referenced
collect2: ld returned 1 exit status
make[3]: *** [core.so] Error 1
make[2]: *** [python/core/core.so] Error 2
make[1]: *** [python/CMakeFiles/python.dir/all] Error 2
make: *** [all] Error 2--
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
