[Qgis-developer] GRASS modules
Byambaa Mendbayar mendbayar_b at mongol.net
Mon Mar 5 02:44:13 EST 2007
Dear Paolo Cavallini and Tim Sutton,
Thanks a lot for you and other GRASS modules developers (Leonardo Lami and
Massimo DiStefano).
How can I see newly added GRASS modules which are announced by you? Those
new modules are already in SVN HEAD or SVN 0.8.0 (I mean 0.8.1)?
How can I use http://www.faunalia.it/download/qgis_grass_0.tar.gz in my
development workstation? I have using following 2 environments which are
XUbuntu + QGIS dev deps and WindowsXP + QGIS dev deps.
Second:
I have trying to using "Raster map calculator" for simple operation like
Add, Sub and etc... My calculation is that:
r.mapcalc
calcRes=(((raster_3x5.1 at ubap.sbd.15khoroo+raster_3x5.2@ubap.sbd.15khoroo)-ub
_sar_topo_3x5 at ubap.sbd.15khoroo))
Successfully finished
Note:
All layers which are used above calculations are same sized raster images. I
mean each image's extends are same to each other.
After that my output "calcRes" raster image is shifted, I mean outputted
image's coordinate was modified. Also outputted image's each pixel data have
same values, which are Minimum value: 850.655; Maximum value: 850.655.
What am I wrong? Is it my fault or system (GRASS modules) fault? How I check
my GRASS plugin's "Raster map calculator" modules work correct?
Best regards,
Byambaa Mendbayar
P.S
Thank you for reading my chaos mail, and your patient.
-----Original Message-----
[mailto:qgis-developer-bounces at lists.qgis.org] On Behalf Of Paolo Cavallini
Sent: Monday, February 26, 2007 5:31 PM
To: QGIS-dev
Cc: Leonardo Lami
Subject: [Qgis-developer] GRASS modules
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
Thanks to Leonardo Lami and Massimo DiStefano we now have quite a few
GRASS modules added to the qgis-grass plugin. They have been tested and
no issue has been found. You can download it from:
It would be good if they could be added to the next release of qgis.
All the best.
Paolo Cavallini
email+jabber: cavallini at faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFF4qjR/NedwLUzIr4RAl12AJwKdlIRt33L0MVWmyu447ETQZ20KACgjGEw
CrNLNCFEI+6Ifz5YHllBaX8=
=011i
-----END PGP SIGNATURE-----
Qgis-developer mailing list
Qgis-developer at lists.qgis.org
http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
