[Qgis-developer] GRASS modules
Tim Sutton
tim at linfiniti.com
Mon Mar 5 08:48:08 EST 2007
Hi
The modules are not committed yet but will be soon. Getting from the
tarball you mentioned is the best way.
Regards
Tim
2007/3/5, Byambaa Mendbayar <mendbayar_b at mongol.net>:
> Dear Paolo Cavallini and Tim Sutton,
> Thanks a lot for you and other GRASS modules developers (Leonardo Lami and
> Massimo DiStefano).
> How can I see newly added GRASS modules which are announced by you? Those
> new modules are already in SVN HEAD or SVN 0.8.0 (I mean 0.8.1)?
> How can I use http://www.faunalia.it/download/qgis_grass_0.tar.gz in my
> development workstation? I have using following 2 environments which are
> XUbuntu + QGIS dev deps and WindowsXP + QGIS dev deps.
> Second:
> I have trying to using "Raster map calculator" for simple operation like
> Add, Sub and etc... My calculation is that:
> r.mapcalc
> calcRes=(((raster_3x5.1 at ubap.sbd.15khoroo+raster_3x5.2@ubap.sbd.15khoroo)-ub
> _sar_topo_3x5 at ubap.sbd.15khoroo))
> Successfully finished
> Note:
> All layers which are used above calculations are same sized raster images. I
> mean each image's extends are same to each other.
> After that my output "calcRes" raster image is shifted, I mean outputted
> image's coordinate was modified. Also outputted image's each pixel data have
> same values, which are Minimum value: 850.655; Maximum value: 850.655.
> What am I wrong? Is it my fault or system (GRASS modules) fault? How I check
> my GRASS plugin's "Raster map calculator" modules work correct?
> Best regards,
> Byambaa Mendbayar
> P.S
> Thank you for reading my chaos mail, and your patient.
> -----Original Message-----
> From: qgis-developer-bounces at lists.qgis.org
> [mailto:qgis-developer-bounces at lists.qgis.org] On Behalf Of Paolo Cavallini
> Sent: Monday, February 26, 2007 5:31 PM
> To: QGIS-dev
> Cc: Leonardo Lami
> Subject: [Qgis-developer] GRASS modules
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all.
> Thanks to Leonardo Lami and Massimo DiStefano we now have quite a few
> GRASS modules added to the qgis-grass plugin. They have been tested and
> no issue has been found. You can download it from:
> It would be good if they could be added to the next release of qgis.
> All the best.
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFF4qjR/NedwLUzIr4RAl12AJwKdlIRt33L0MVWmyu447ETQZ20KACgjGEw
> CrNLNCFEI+6Ifz5YHllBaX8=
> =011i
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
