[Qgis-developer] QGIS crash on Mac OS X -- 0.8 release branch
Tom Elwertowski
telwertowski at comcast.net
Sat May 12 20:45:11 EDT 2007
Gary Sherman wrote:
> On May 11, 2007, at 8:43 PM, Tom Elwertowski wrote:
>> I checked a handful of cmake generated files and the paths are what I
>> expect. Plenty of -I/Library/Frameworks/xxx.framework/Headers and no
>> -I/usr/local/include so I am baffled as to why I end up with an
>> inconsistent build.
>> This makes me wonder if you have some non-framework headers which are
>> being picked up and producing an inconsistent build.
> Your explanation makes sense, but I'm at a loss as to how to
> troubleshoot it.
More information but no solution.
I built QGIS 0.8 and 0.9 on a clean system to be sure there are no extra
files beyond the needed dependencies. The problem exists only in 0.8.
I discovered that when I run QGIS inside GRASS, I can load a shp file
without crashing. I then removed libgrassplugin.so and
libgrassprovider.so from qgis0.8.1.app/Contents/MacOS/lib/qgis/ and
found that I can open a shp file when running QGIS directly without GRASS.
The problem therefore seems to be related to how frameworks are linked
with the GRASS addons in 0.8. When the frameworks get linked to 0.8,
they seem to be requiring the presence of GRASS.
Tom
