[Qgis-developer] QGIS crash on Mac OS X -- 0.8 release branch
Gary Sherman
sherman at mrcc.com
Sun May 13 01:10:55 EDT 2007
On May 12, 2007, at 8:56 PM, William Kyngesburye wrote:
> What are the Qgis grass plugin/provider linked to? Try otool -L on
> them. They may be picking up the GDAL GRASS libraries instead of
> the GRASS.app libraries.
Pardon the long list but here they are:
libgrassplugin.so:
Qt3Support.framework/Versions/4/Qt3Support (compatibility
version 4.2.0, current version 4.2.3)
QtSvg.framework/Versions/4/QtSvg (compatibility version
QtGui.framework/Versions/4/QtGui (compatibility version
/System/Library/Frameworks/Carbon.framework/Versions/A/
Carbon (compatibility version 2.0.0, current version 128.0.0)
/System/Library/Frameworks/QuickTime.framework/Versions/A/
QuickTime (compatibility version 1.0.0, current version 12.0.0)
QtXml.framework/Versions/4/QtXml (compatibility version
QtSql.framework/Versions/4/QtSql (compatibility version
QtNetwork.framework/Versions/4/QtNetwork (compatibility
QtCore.framework/Versions/4/QtCore (compatibility version
/usr/lib/libz.1.dylib (compatibility version 1.0.0, current
version 1.2.3)
/System/Library/Frameworks/ApplicationServices.framework/
Versions/A/ApplicationServices (compatibility version 1.0.0, current
version 22.0.0)
@executable_path/lib/libqgis_core.dylib (compatibility
version 0.0.0, current version 0.0.0)
@executable_path/lib/libqgisgrass.dylib (compatibility
/Applications/GRASS.app/Contents/Resources/grass-6.2.1/lib/
libgrass_gis.dylib (compatibility version 6.2.0, current version 6.2.0)
libgrass_vect.dylib (compatibility version 6.2.0, current version 6.2.0)
libgrass_dig2.dylib (compatibility version 6.2.0, current version 6.2.0)
libgrass_dbmiclient.dylib (compatibility version 6.2.0, current
version 6.2.0)
libgrass_dbmibase.dylib (compatibility version 6.2.0, current version
6.2.0)
libgrass_shape.dylib (compatibility version 6.2.0, current version
6.2.0)
libgrass_dgl.dylib (compatibility version 6.2.0, current version 6.2.0)
libgrass_rtree.dylib (compatibility version 6.2.0, current version
6.2.0)
libgrass_datetime.dylib (compatibility version 6.2.0, current version
6.2.0)
libgrass_linkm.dylib (compatibility version 6.2.0, current version
6.2.0)
libgrass_form.dylib (compatibility version 6.2.0, current version 6.2.0)
libgrass_gproj.dylib (compatibility version 6.2.0, current version
6.2.0)
/Library/Frameworks/PROJ.framework/Versions/4.5/PROJ
(compatibility version 6.0.0, current version 6.2.0)
/Library/Frameworks/SQLite3.framework/Versions/3.3/SQLite3
(compatibility version 9.0.0, current version 9.6.6)
/Library/Frameworks/GEOS.framework/Versions/2.2/GEOS
(compatibility version 3.0.0, current version 3.1.0)
/Library/Frameworks/GDAL.framework/Versions/1.4/GDAL
(compatibility version 13.0.0, current version 13.0.0)
/usr/lib/libstdc++.6.dylib (compatibility version 7.0.0,
current version 7.4.0)
/usr/lib/libgcc_s.1.dylib (compatibility version 1.0.0,
current version 1.0.0)
otool -L libgrassprovider.so
libgrassprovider.so:
version 1.2.3)
version 22.0.0)
version 6.2.0)
6.2.0)
6.2.0)
6.2.0)
6.2.0)
6.2.0)
6.2.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0,
current version 88.3.7)
There is a reference to the GDAL framework in each of them. Is that
the problem? If I start QGIS from GRASS it does work.
-gary
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Micro Resources: http://mrcc.com
*Geospatial Hosting
*Web Site Hosting
"We work virtually everywhere"
